Results 1 to 6 of 6
    Sep 17 2022
    Buffalo, NY
    New S6 owner question about braking and throttle response
    Hello everybody.
    I recently bought a 2018 S6 and I absolutely love the car. This is the first modern German car I have ever owned. The tech is really cool but
    I don't like not being fully in control of car.
    What I mean is.... soft rev limiter, upshifting in manual mode before I hit the paddle (at less than full throttle), etc.
    My biggest dislike is brake pedal response. I like instant braking when I hit the brake pedal and it seems like I have to brake 1 sec ahead of when I normally would (like say in my Vette) for the brakes to start biting. Also, during off idle acceleration there is also a slight delay. This is in dynamic mode / sport mode active.
    I imagine this is programmed into the stock tune by the Audi engineers but it's annoying. Just wanted to check with you guys to make sure this is working as intended.
    Car is 100% stock.
    Thanks.
    I will eventually get a tune and hopefully that will fix it. Do I have to just deal with it right now?
    2018 S6 with Black Optic / Sport Diff / Sport Exhaust
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Sleeper71 View Post
    ECU and TCU tunes will help; you'll have to decide for yourself if they help enough.
    Sep 17 2022
    Buffalo, NY
    Ok thanks Alabama. That's what I thought.
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    If you want a firmer brake pedal feel, stainless lines MIGHT help a bit. But that initial travel will not likely be minimized.
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    I've got the exact same gripes with the platform as you. I'm still on the stock ECU/TCU tunes as well.
    The brake pedal feel in these cars is by far the softest I've encountered in any Audi. The stopping action is there, it just requires more pedal travel. When I hop in our 2017 Q7 I always feel like I'm going to fly through the windshield the first time I tap the brakes.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Assuming you have OEM pads/rotors? If you don't like the initial bite with OEM, you wont like aftermarket pads where the initial bite is a bit less. Like JWebb said, stainless lines may help a little
    Maybe I have gotten used to it, but I prefer being able to control the pressure in the S7 more, versus barely tapping on the pedal in my wife's jeep feels like I am learning to drive all over again.
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
