Results 1 to 6 of 6
Thread: Engine Mounts
    Junior Member One Ring
    Jan 11 2019
    Mesa Arizona
    Engine Mounts
    Any guidance on replacing Left and Right engines mounts on a 2016 A6 with 2.0t? Thanks.
    Aug 08 2008
    2017 Q5
    Houston, TX
    no guidance but was quoted around 5k from my local dealership to do mine. a local euro tuner shop quoted $2900.
    __________________________________________________ ____________________________
    2016 Aud S7 - Massaging Seats are pretty neat
    2013 VW Passat TDI - Black - sold
    2015 S4 Prestige - DSG - Mythos Black Metallic 2003 Civic EX 5spd - Gone
    2010 F-150 Lariat Super Crew - Gone 1988 Toyota Supra N/A 5spd - Gone
    2008 A4 2.0T 6spd - Gone 1999 Civic EX auto - Gone
    UTSA Alumnus - #BIRDSUP #WBC #GETROWDY
    Sep 16 2020
    West Michigan
    I did both of mine by myself in the garage on my 3.0t.
    I'd suspect that the 2.0t would be easier.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Junior Member Two Rings
    Nov 05 2021
    2017 Q7 PP 2.0L
    Houston Texas
    2.0T is easier than 3.0L. $600 should get you both mounts, then either jack up engine from below with piece of wood (how I did my DIY), or use an engine holder to jack it up about 2 inches.
    Lot of DIY's on youtube, check for A4, same thing for 2.0L.
    My DIY (short version): https://www.audiworld.com/forums/a6-...a6-c7-3036231/
    2013 A6 Quatro PP 2.0L
    2017 Q7 PP 2.0L
    Sep 16 2020
    West Michigan
    I bought performance mounts for my 3.0t for under $500.
    Established Member Two Rings Benji16's Avatar
    Apr 27 2020
    Eustis
    For 2.0t its the same procedure exept no need to remove oil cooler like 3.0t i highlighted the bolts that need to be removed on both sides. Not need to remove fender liner just toss it to one side and have someone hold it while remove the 3 bolts to save time. Jack up engine and remove the mounts. Dont strip the center motor mount triple square bolt or you are focked.20221114_035933.jpg20221114_035926.jpg20221114_035909.jpg
