Results 1 to 8 of 8
    Jun 17 2022
    United states
    2012 a6 3.0t running rich
    Hi everyone I知 new here and I have a 2012 Audi a6 3.0t 12mpg city and a little higher highway running rich on both banks with no codes. The reason I know I知 running rich is because I can smell the exhaust and the upstream wideband o2 is reading low voltage and the downstream narrowband sensor is reading up to .900v rarely goes to .800v. My stft and ltft are positive when I believe they should go lean from the o2 reading. I have changed o2 sensors I have replaced the cats with magnaflow oem grade direct fit with no cat efficiency codes, new spark plugs, new pcv, new intake manifold gaskets, new map sensors, new coolant temp sensor, new oem fuel filter in the tank and had injectors flow tested and cleaned. I removed the spark plugs not even 1000 miles and they are turning black from all the extra fuel. Thanks in advance
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Based on what I just googled, clean the MAF and put a new air filter in. If you have a CAI with a cone type filter you could run into problems with an over oiled filter that manages to fowl the MAF. Other indications is possibly a faulty HPFP that might be leaking down. It sounds like you have addressed all the other potential problems
    Jun 17 2022
    United states
    Hey thanks for the reply but my engine doesn稚 have a Mass air flow sensor and I have the stock air filter.
    Veteran Member Three Rings prestige.phantom's Avatar
    Jul 16 2018
    Connecticut
    Is the car tuned?
    2013 Audi A6 3.0T Prestige
    | Phantom Black Pearl | Nougat Brown interior | LED Headlights | Cold Weather PKG | 20" Sport PKG Wheels & 3 Spoke Heated Wheel | Fine Grain Ash Natural Inlays | Michelin Pilot Sport AS3+ Y | OEM "Rings" Puddle Lights |
    | AWE Touring Exhaust | JHM Non-Res DPs | Eibach Pro Kit & Bilstein B4 Sport Shocks | Eurocode Trans Mount | JBX Carrier | S8 Front Brakes w/ EBC Red Pads | 034 ECU 93 STG 1, TCU, Rear Swaybar, and Endlinks |
    IG: @prestige.phantom @ctautoart
    Jun 17 2022
    United states
    No it is not. I知 wondering why the ecu isn稚 cutting back on fuel with those o2 voltage reading rich.
    Active Member One Ring SWEAT's Avatar
    Aug 20 2022
    2011 nissan titan & 2020 yahama raptor 700r SE
    Tuscaloosa Alabama
    Do you think a tune will help with running rich?
    Sent from my SM-S916U using Audizine Forum mobile app
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    In a lot of cases, doesn't this almost always trace back to O2 sensors that need replacing?
    Aug 20 2022
    Tuscaloosa Alabama
    Next weekend I'm going to get it replaced! I have a few issues after 6 to 7 months later, not test driving!
