Results 1 to 2 of 2
    Aug 25 2022
    MA
    Fuel Rail/System Pressure P0087 00 [096] - Too Low
    Having issues with my 2015 A7 fuel system. Low pressure.
    I am attaching the scanned codes, if someone can help.
    thanks.
    Sunday,06,November,2022,13:29:09:36994
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
    Data version: 20220830 DS341.0
    www.Ross-Tech.com
    VIN: WAU2GAFCXFN025539 License Plate:
    Mileage: Repair Order: Fuel_rail-Issues
    Address 01: Engine Labels: 06E-907-551-CGW.clb
    Control Module Part Number: 4G0 907 551 J HW: 4G0 907 551 A
    Component and/or Version: 3.0l V6 TFSIH07 0004
    Software Coding: 1A2A0034056601060000
    Work Shop Code: WSC 02391 785 00200
    ASAM Dataset: EV_ECM30TFS0214G0907551J 001004 (AU57)
    ROD: EV_ECM30TFS0214G0907551J.rod
    VCID: 30391C80EAAA5BAB573-8064
    4 Faults Found:
    6058 - No Communications with Cruise Control (Front) Distance Sensor
    U0235 00 [045] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 20
    Mileage: 174101 km
    Date: 2022.11.05
    Time: 14:33:49
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 92 °C
    Intake air temperature: 63 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 11.984 V
    Unlearning counter according OBD: 40
    Engine speed: actual: 0 /min
    T_AST_ENVD: 0.00 s
    Gear: 0
    Engine: operating status: ES
    Battery voltage: 12.593750 V
    Vehicle speed: actual: 0 km/h
    6238 - Fuel Rail/System Pressure
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 174109 km
    Date: 2022.11.05
    Time: 16:10:29
    Engine RPM: 633.00 /min
    Normed load value: 17.3 %
    Coolant temperature: 80 °C
    Intake air temperature: 69 °C
    Voltage terminal 30: 12.695 V
    Unlearning counter according OBD: 37
    Engine speed: actual: 640 /min
    MAF_ENVD: 185.20000 mg/stroke
    Coolant temperature (unfiltered): 80.25 °C
    FUEL_MASS_REQ_I_CTL_ENVD: 14.132813
    FUP_ENVD: 6792.5885 hPa
    FUP_EFP_ENVD: 4773.4 hPa
    16903 - Vapor Bubble Formation in Low-Pressure Fuel Circuit
    P125B 00 [040] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 174108 km
    Date: 2022.11.05
    Time: 15:01:14
    Engine RPM: 1462.00 /min
    Normed load value: 26.3 %
    Vehicle speed: 30 km/h
    Coolant temperature: 89 °C
    Intake air temperature: 39 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.913 V
    MAF_ENVD: 0.00000 mg/stroke
    Coolant temperature (unfiltered): 81.00 °C
    FUP_EFP_ENVD: 6137.22 hPa
    6208 - Fuel Trim; Bank 1 (Mult)
    P1128 00 [096] - System too Lean
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 174108 km
    Date: 2022.11.05
    Time: 15:01:13
    Engine RPM: 1412.00 /min
    Normed load value: 31.4 %
    Vehicle speed: 29 km/h
    Intake air temperature: 40 °C
    Engine speed: actual: 1408 /min
    MAF_ENVD: 239.67058 mg/stroke
    Coolant temperature (unfiltered): 89.25 °C
    Engine: operating status: PL
    T_AST_ENVD: 745.30 s
    STATE_LS_ENVD[1]: 2
    Readiness: 0000 0100
    Aug 25 2022
    MA
    Quote Originally Posted by MikeB12D View Post
    thanks.
    www.Ross-Tech.com
    4 Faults Found:
    U0235 00 [045] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 20
    Mileage: 174101 km
    Date: 2022.11.05
    Time: 14:33:49
    T_AST_ENVD: 0.00 s
    Gear: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 174109 km
    Date: 2022.11.05
    Time: 16:10:29
    P125B 00 [040] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 174108 km
    Date: 2022.11.05
    Time: 15:01:14
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 174108 km
    Date: 2022.11.05
    Time: 15:01:13
    STATE_LS_ENVD[1]: 2
    More data for fuel pressure with engine running and engine off
