Results 1 to 15 of 15
    Jan 07 2011
    2013 C300 4Matic
    Hardwire blackvue dashcam
    Hey guys! Just picked up a 2019 Rs5. Any ideas which fuses /box to use to add the add a fuse tap so it can run continuously when the car is off?
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Senior Member Three Rings angrycatmeow's Avatar
    Jan 22 2022
    FL, US
    I used a 12v tester and found some blanks in the fuse box under the dead pedal. You can find 12v switched and constant in there.
    Sent from my SM-F936U1 using Tapatalk
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by angrycatmeow View Post
    Didnt even know there was a fuse box under there my salesman didnt ship me my manual yet.
    Thanks! Do u remember exactly which ones u used? Or have a pic of ur setup?
    Present:
    IG: bknewtype
    Jan 22 2022
    FL, US
    I didn't piggyback, there's just open slots in there
    Jan 07 2011
    2013 C300 4Matic
    Did u use the mini ones or the bigger ones? Seems the bigger ones dont fit in it perfectly :(
    Present:
    IG: bknewtype
    Jan 22 2022
    FL, US
    I think I modified the fuse holder so the wire comes out of the top instead of the side. Just melted/softened the plastic and used some epoxy to patch it back up.
    Jan 07 2011
    2013 C300 4Matic
    Gotcha. Seems like none of the bigger fuses are acc that are free and only the tiny ones
    Present:
    IG: bknewtype
    Jan 22 2022
    FL, US
    Yeah the side rails next to the fuses are too tall. It's a pain. I couldn't find any other style of fuse holder to make it work but my modified ones are holding up fine.
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    I ran my 2 channel all the way back (since there had to be a wire for the rear camera anyway) and tapped into the rear fuse box, where I also added the blackvue backup battery
    '18 S4 Prestige; all packages
    Jan 07 2011
    2013 C300 4Matic
    Gonna give it a try again. I ordered the mini add a fuse
    Present:
    IG: bknewtype
    Jan 07 2011
    2013 C300 4Matic
    So this is weird was wondering if anyone can chime in
    Im running a blackvue dr900x with a power magic pro
    I have a regular sized add a fuse ( for always on ) and a mini add a fuse ( for switched , also my radar power tapped in ) and 2 ground wires ( 1 for pmp 1 for radar )
    Initially when i put everything together , the pmp turned on, the camera turned on. I tried to turn the pmp off , but it wouldnt turn off. So i think i accidentally put both add a fuses into a constant slot
    I unplugged the fuses and checked the slots and plugged them back into a switched and constant, and it finally worked ( camera on, pmp on, switch for the pmp worked ). However i realized i forgot to ground the radar, so i started to undo the ground so i can stack the radar ground on top of the pmp ground
    Now, nothing works. Same slots dont work. Tried diff slots and it doesnt work. Pmp doesnt power on. Camera doesnt power on. And my radar isnt on
    What’s strange is i have an old PMP and when i swapped to it, it sometimes turns on, but the camera doesn’t turn on, and i cant switch the pmp off
    Cant figure this out.
    Have a add a fuse tapped into a always on
    Have a add a fuse tapped into a switched
    Ground for both pmp and radar secured
    Nothing turns on
    Any ideas or help is greatly appreciated
    Present:
    IG: bknewtype
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Post some photos or a video
    Jan 07 2011
    2013 C300 4Matic
    Will do. Have to be tomorrow. Work today and daylight savings means its gonna be pitch black when im home so cant work on it.
    Present:
    IG: bknewtype
    Established Member Two Rings Advocado's Avatar
    Nov 08 2022
    Audi S5 Sportback (B9.5) & Audi Q5 Backsport (80A)
    Masshole
    I've just connected it to the mirror... 30 min on everything, no need to tear down A-pillars.
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by Advocado View Post
    I had to regardless since i have a rear cam as well. But i finally got everything working lol i was using the wrong switched fuse
    Present:
    IG: bknewtype
