Results 1 to 7 of 7
    Nov 06 2021
    Singapore
    Timing chain elongation 3.0TFSI Engine
    128000KM car
    P0321 00 Engine speed sensor (G28)- implausible signal
    P0337 00 Crankshaft position sensor (G28) - Signal too low
    P0336 00 Crankshaft position sensor (G28) - Missing Tooth
    Car limits itself to 3800rpm Max when i go wide open throttle. Take double the cranks to start up after sitting for more than 4hours. No cold start rattles at all.
    has my time come? Time to do the timing chain replacement? No way to do chain tensioners on this car without dropping the engine? Damn really missing my N54.
    Anyone who has experienced the same or already done their timing chains appreciate the comment. Thanks
    Nov 06 2021
    Singapore
    Did anyone do a G28 Crank position sensor replacement and solved these codes?
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    I was getting P0016 and P0018 and tried replacing the crank sensor as well as swapping cam sensors and replacing the VVTs as well. No luck at all, wound up pulling the engine to replace all 4 chains. Labor is $3000 to $5000 USD depending on where you have it done. If you do it yourself then source the parts with ECS or FCP you can get the generic chains for less than OEM. The chains they sell are OEM without the OEM markup. Tensioners you are gonna have to buy OEM.
    Nov 06 2021
    Singapore
    Quote Originally Posted by Valpo A7 View Post
    Thanks Valpo. i actually came across your thread on your timing chain replacement job. you did yours around 230,000 miles. mine is only at 80,000 miles..... Seems my codes are also different and all pointing to G28 sensor. guess ill try out the G28 replacement first and monitor.
    Nov 27 2018
    Valparaiso, IN
    I was at 204,XXX miles. You can try the crank sensor but I was told by a tech that the engine won’t run with a bad crank sensor.
    Nov 06 2021
    Singapore
    Update on situation. Removed G28 crank sensor, found out plastics had turned brittle and the housing had cracked, allowing engine oil to spill into the electronics/connections inside. This create lots of random errors. Monitoring new sensor replacement, fingers crossed! hope that there is no need for timing chain work until 200,000 miles!
    Aug 08 2008
    2017 Q5
    Houston, TX
    best of luck! hoepfully no issues after this.
    - - - Updated - - -
    best of luck! hopefully no issues after this.
    __________________________________________________ ____________________________
    2016 Aud S7 - Massaging Seats are pretty neat
    2013 VW Passat TDI - Black - sold
    2015 S4 Prestige - DSG - Mythos Black Metallic 2003 Civic EX 5spd - Gone
    2010 F-150 Lariat Super Crew - Gone 1988 Toyota Supra N/A 5spd - Gone
    2008 A4 2.0T 6spd - Gone 1999 Civic EX auto - Gone
    UTSA Alumnus - #BIRDSUP #WBC #GETROWDY
