Results 1 to 9 of 9
    Senior Member Three Rings angrycatmeow's Avatar
    Jan 22 2022
    FL, US
    P0171 - Fuel Trim, Bank 1 System too Lean
    2018 S5, 50k mi. Got this code about 3 weeks ago, cleared it, and it came back yesterday. Did a search and didn't see any hits on this specific code for B9 S4's and S5's. Looking for suggestions on where to start troubleshooting.
    IE stage 1
    CTS Turbo inlet
    P34 intake
    CTS intercooler/charge pipes
    TSB 2059446 performed, PCV breather line replaced
    https://static.nhtsa.gov/odi/tsbs/20...82173-0001.pdf
    Trouble codes:
    P017100 - Fuel Trim,Bank1 System too Lean
    Intermittent
    Date: 2022-11-04 15:57:46
    Mileage: 80099 km
    Priority: 2
    Malfunction frequency counter: 1
    Unlearning counter: 255
    Engine speed: 835.50 1/min
    Normed load value: 10.2 %
    Vehicle speed: 0 km/h
    Coolant temperature: 86 °C
    Intake air temperature: 33 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 14.140 V
    Dynamic environmental data: 209628107A0311BD0CB83EFC05121605711514041770000137 4110100346
    Junior Member Two Rings
    Aug 09 2022
    Golden Shoe
    Quote Originally Posted by angrycatmeow View Post
    IE stage 1
    CTS Turbo inlet
    P34 intake
    Trouble codes:
    Intermittent
    Mileage: 80099 km
    Priority: 2
    Hi there. I got this exact code today as well.
    2019 S4
    IE Stage 1 93
    IE FMIC
    P34 Intake
    I've been noticing rough cold starts the colder the weather.
    Did you ever figure this out?
    Seems like it could be a lot of things really.
    Jan 22 2022
    FL, US
    Quote Originally Posted by AudiShport View Post
    2019 S4
    IE Stage 1 93
    IE FMIC
    P34 Intake
    I honestly think it was an early sign of this: https://www.audizine.com/forum/showt...bracket-loose!
    You know how these cars don't like electrical gremlins/low batteries. I think when the belt slipped on the alternator it caused an intermittent low voltage, and I would get that code and a couple others for low voltage/implausible signal type stuff. Ever since fixing the alternator issue, it hasn't been back (knock on wood).
    I've also noticed some rougher idling in cooler weather until the revs settle down, then it's stable. I haven't heard much about carbon cleaning on these engines, but I assume it's carbon build-up.
    Aug 09 2022
    Golden Shoe
    Interesting, mine is not driven much and sometimes I'm lazy to put it on trickle charging so the low voltage would apply here!
    And I hope it's not carbon build up I'm only at 18k miles!
    Cheers
    Jan 22 2022
    FL, US
    Oh well in that case, lets just chalk it up to the tune and move on :) We have very similar mods but my car is at 50k or so.
    Junior Member One Ring
    Jan 03 2023
    Ft Worth, Texas
    Just for reference I had the same code as well (IE Stage 1 E85) I solved it by flashing back to stock, then re-flashing back to E85 tune. No codes as of yet...2018 S5 SB 48K mi
    Established Member Two Rings DC3P0's Avatar
    Aug 28 2023
    2016 CRV, MK7 GTI
    PNW, USA
    sorry to revive an old thread but anyone ever get to the bottom of this code? I was on IE Stage 1 - 91 when I got it. I have a FMIC and an intake as well. Flashed back to stock soon after and haven't had any issues since. Been about two weeks.
    Just curious if people kept rolling with their IE stage 1 or what else you might have tried.
    IE wants me to log it, I'm just not really into trying to make it happen again on their tune. Too much noise out there right now.
    Junior Member One Ring jackmcg12's Avatar
    Dec 04 2018
    Kentucky, USA
    Quote Originally Posted by DC3P0 View Post
    I was seeing the same thing on a 6-month old S4 running IE Stage 1 - 93. Flashed back to stock and having driven some of the same places that it would throw the issue, haven't seen it pop back up.
    After some issues I had with their TCU Flash a month ago, mixed with some of these CELs on the B9 platform (compared to rocksolid tune on the B8.5 2.0t platform) I can't bring myself to stick with them while they beta test with all customers cars. Going 034Motorsports now as stock is lacking.
    Aug 28 2023
    2016 CRV, MK7 GTI
    PNW, USA
    Quote Originally Posted by jackmcg12 View Post
    Yeah I tried recreating the conditions on stock for almost a month. Logged a ton. No CELs, nothing out of whack. Took advantage of the 034 competitor switch discount which made it slightly easier to stomach paying for two tunes.
