Results 1 to 1 of 1
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    Used OEM Plastic Belly Pan/Undertray/Engine & Radiator Support Splash Shield
    Condition: USED - off my 2015 Audi S4 with 77k miles. great condition and I don't really see any damage, no hardware included; but, I'll link some below.
    Part#: 8K1-863-821
    Fitment: It's a Plastic Belly Pan/Undertray/Engine Splash Shield that fits ONLY S4's, S5's, A4's and A5's between 2013 to 2017. It will not fit anything older!
    Hardware info found here: https://www.genuineaudiparts.com/oem...ield-8k1863821
    Price: The price of these are nuts. $240 (damaged) to $380 (new). PM or post a reasonable offer and include your ZIP and I'll try to work up a good deal with you.
    Shipping Origin: 30328 - Atlanta, GA - If you're local I'll be happy to work out meeting you
    Dimensions (which makes shipping difficult, and I'm going to have to make a box for this: 58" x 24" x 1 ... and this is just the dimensions of the item. I'll have to make a box slightly larger. I'd expect about $65-90.
    Side 1:
    Side 2:
    Part #:
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
