Results 1 to 9 of 9
    Junior Member One Ring
    Nov 03 2022
    2012 Q5 Yaw Sensor Fault??
    Hello all, hopefully some 1 can help me.
    I believe my Yaw Sensor is starting to fail.
    I turn the ignition on and my screen says stability control fault, TPMS and ESP light is on. I have to turn on and off the ignition multiple times before my Audi will start. I did searching, sounds like it's the Yaw Sensor but seems to be 2 of them. And I seem to be having a hard time to find the actual location, I read 3 different areas. Under the drivers seat, under the console or under the steering column.
    Any insight will be great.
    Thanks
    Sent from my SM-G935W8 using Audizine Forum mobile app
    Jul 16 2018
    Atlanta
    Do a proper scan and get an actual DTC (diagnostic trouble code). Then work from the factual information.
    All the ESP related acceleration sensors are in a single G419 unit, which is under the rear footwell vent under the carpet under the center of the front left seat. Manual mentions if you drop it, you broke it. So be careful with it.
    Nov 03 2022
    Oh joy, that does sound like a very pleasant job. Sounds of it, I need to lift the carpet just behind the drivers seat?
    Thank yoy
    Jul 16 2018
    Atlanta
    Yeah, and it mentions if there's not a "bar" to lift, you might be doing cutting of the carpet to create the access.
    Google search didn't turn up any real world pics of the situation, but it did turn up a linkable copy of the manual page for the B8 A4 (same system): https://workshop-manuals.com/audi/a4...-g419-/-g536-/
    Nov 03 2022
    Okay thank you.
    I wouldn't need an expensive scanner for scan for this?
    Nov 03 2022
    Well went and picked up a scanner.
    Didn't say anything about stabilitrack failure, but gave me a whole bunch.
    The P0299, I believe my waste gate is leaking. 20221104_204356.jpg20221104_204352.jpg20221104_204337.jpg20221104_192857.jpg20221104_192736.jpg
    Nov 03 2022
    I think the ECM issue is the relay.
    Will pull that out and try to clean it
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    How old is the battery?
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Nov 03 2022
    Battery was changed last year.
    Issue is located, starter relay is causing the issue.
