Results 1 to 21 of 21
    Junior Member Two Rings krzysztofkow's Avatar
    Jun 12 2011
    New York, NY
    What aftermarket heater core comes all-aluminium?
    Hey guys. '05 A4 1.8T. I decided to replace my heater core (tired of flushing it) and ordered a Valeo 812255 from FCP because on their website it shows as an all-aluminium unit, like the original. However, the part that I received has plastic end tanks/pipe connections. I heard horror stories about these, associated with installation and durability, so I am returning it back to FCP. Can anyone recommend an aftermarket heater core brand that comes with aluminium end tanks? Obviously parts vendor website pics can't be trusted and I don't want to blindly keep ordering till I get lucky. Thank you in advance for your input.
    Mar 21 2013
    whitesboro,ny
    I had a issue with mine and this radiator place near me said to use liquid dishwasher soap to clean it out. What you do is up at firewall you disconnect the 2 hoses and you hook up garden hose and flush it that way. You find which one is inbound and the other return and use the soap and put some through and let it set. Then you flush it till it's clear. Then use air hose to blow out water. Then refill the system but make sure your mixing it with distilled water. Don't ever use city water. Then fill it up and you should be good to go. I hope this helps that's what I did with mine and worked like a charm.
    Sent from my SM-F926U using Audizine Forum mobile app
    Jun 12 2011
    New York, NY
    Thanks Chuck. I tried the flush procedure several times, each time the fix was short term, that's why I decided to replace the core. I just did additional research and it seems like Spectra 99373 is all-aluminium and available on amazon for $60. Will give it a try and update with results.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by krzysztofkow View Post
    Good call. Here's what you are dealing with: Clicky clickŪ️
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Parts descriptions should tell you whether or not it's an all aluminum unit.
    also not to plug them but ECS has heaps of different brands.
    Jun 12 2011
    New York, NY
    Thank you Old Guy. I've had your thread bookmarked for a year now, lol. Finally got the motivation to follow through on it.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Quote Originally Posted by TobiqueSlang View Post
    Last few orders I have placed with them have arrived really fast.
    Dec 28 2008
    How long should 1 expect a new core to last before the same condition applies?
    Feb 27 2011
    Winnipeg
    I put a spectra one in my car back in 2014, so far so good. Thats really weird that valeo has a plastic end take as the OE core on mine was a valeo
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by my1stturbo View Post
    Replaced mine in 2016. Still have good heat.
    Mar 28 2015
    The other factors that matter are how good is your coolant and make sure the engine grounds are intact. Both affect heater core life.
    Mar 01 2004
    Cleveland, OH
    Quote Originally Posted by chuckb825 View Post
    I would add that if you can get a sprayer to attach to your garden hose with a threaded end on the sprayer side you can get a lot more pressure/pulsing to break up whatever is clogging the heater core. I wasn't able to get my heater core to flush properly until I used this with the garden hose flush adaptor thing you get at the auto parts store.
    Something like this
    I personally would avoid changing out the heater core at all cost. I changed one on an Audi A6 and it was hard to get it to seal properly. I had to redo it multiple times because it wouldn't stay sealed. Flushing it an inconvenience but 10x easier than having to mess with the core to stop a leak. I'm sure there are solvents to clean a heater core.
    Also make sure you're bleeding the system properly after flushing the heater core. A air pocket at the top of the hose where the heater comes from the firewall will restrict flow through the heater core which will reduce the heat output.
    Mar 21 2013
    whitesboro,ny
    Quote Originally Posted by inliner311 View Post
    Something like this
    Oh yeah that's what I was told about it avoid it if you can. Once you get the liquid detergent in there let it soak for quite awhile. And if the water doesn't come blasting out then put more detergent in and do it over and over. Once the water comes blasting out then you know you have broke through. Then I would do it again so you know you have it cleaned out pretty good. And just remember to use distilled water if you mixing it and you shouldn't have any other issues.
    Dec 28 2008
    Thanks. Thinking my issue is either replaced core but no flush or system isn't sealed for some reason and getting air getting back in the system. Will pressurize and see if I can find a leak.
    Jan 24 2010
    Paramus,NJ USA
    Why are you loosing heat or coolant? Is it over heating? Could be a crack cylinder head quite common.
    Ziddy Autowerks
    Mar 01 2004
    Cleveland, OH
    I didn't use detergent but I knew it was clear because all the sediment that came out in the bucket. I went both directions a couple times and used hot water. Pulsed it a bunch of times too. I did a final flush with distilled water and a funnel to clear out any tap water in the heater core.
    Dec 28 2008
    Quote Originally Posted by EuroxS4 View Post
    I'm not necessarily loosing coolant that I notice in any measurable quantity. I tried a block test to see if there was exhaust fumes from coolant but that failed. I had a leak from thermostat due to a failed o ring but after replacement heat is still hit or miss. Il try to pressurize the system myself or else will try a local shop to see if they can figure out the issue.
    Jan 24 2010
    Paramus,NJ USA
    best way to flush a core is to use benz citric acid with boiling hot water. flushing back and forth. Even then its hit or miss.
    Ziddy Autowerks
    Dec 28 2008
    Not sure the core is blocked again or something else going off. Hose is off for the winter but may try a flush again if I don't find a leak anywhere.
    Mar 01 2004
    Cleveland, OH
    Have you tried bleeding the upper heat core hose at the firewall while the coolant tank is prop up vertically? The upper heat core hose is the highest point of the system and air can collect there. By propping up the tank it makes it the highest point which should help force the air out the little bleeder hole at the hose.
    Dec 28 2008
    I've tried bleeding the car endlessly. I'm pretty sure I did it with the tank vertical and the heater core hose exposed as I've have B5 Passat as dailys since 2003 or so and had to do this a few times. But can't hurt to try it again tomorrow.
