So i was finally able to pick up a blue 2018 audi rs3 with some mods on it with only 20k miles. (Mods for only 4k).
After driving the car 3,000 miles to get it home and learning all about it I've enjoyed every second of driving it.
I do have some questions about it i can't seem to find a solid answer on.
1) First being the car has a DS1 in it and has a flex fuel sensor. However the sensor wasn't wired in yet. So i wired in the signal wire to pin 15 of the obd2 port, used an add a fuse to a good/tested 12v port, and the ground wire.
After hooking it up i assumed the ds1 would see the signal and automaticlly overwrite the manually set amount of e85 % that i had set. But every time i open up the browser i only see the manual number that i set which is 8% (due to running 92 oct and not full e85 since there are no stations next to me).
Is there something I'm missing? Do i need to somehow clear the manually set amount in order for the flex fuel sensor to tune to the proper fuel mixture?
2) Second being after driving it today in the rain it feels as if the car constantly cuts all power under acceleration even with traction control on, single press for off, or hold for fully off. This is also at freeway speeds. If i roll onto the throttle it will either pull power on and off or kill it completely almost as if you're out of fuel. (Wondering if the flex fuel sensor could be causing this, although it had no issues in the dry yesterday).
As far as i know the car is not spinning the wheels either. Cause at 80mph and pushing on it in 4-5th gear shouldn't cause the tires to break loose.
As for specs this is what is done to the car.
2018 Audi RS3
Mods
IE Full Carbon Intake
APR 4" Turbo Inlet
Unitronic Catless Downpipe
CTS Turbo complete hotside piping
Unitronic Intercooler
APR Throttle Body Inlet
Unitronic 1000cc injectors
Unitronic Stage 2 Trans Tune
Ethanol Content Sensor wired for integration with DS1
DS1 with Pro tune from Darin Dichiara
STG2 Full Flex Fuel
034 Motorsports Front and Rear Subframe lockdown kits
Urotuning Dogbone Mount
If anyone has any good insight on this i'd greatly appreciate it. I do use the search button as well. I'm an avid reader when it comes to searching for info on my vehicles.
Sent from my SM-S908U using Audizine Forum mobile app
