Results 1 to 6 of 6
    Apr 03 2021
    PNW
    Angry Disturbing Discovery! Rodents and Wiring
    While doing my oil change this evening I made a terrible discovery. The wiring harness just below the oil filter and leading towards the firewall has been munched on! Most of it still looks intact except for the outer housing and the final wire at the back has been severed! I have no idea how long it has been like this and I have yet to get any warning lights and the car seemingly runs great... Can someone please help me identify what wires/plugs these are and can just this section be repaired or replaced or is it the end of a much larger harness? I did as thorough of a search of the rest of the engine bay and everything else seems fine but no way of being 100% certain! I guess im looking for some deterrent recs too if you have them.
    PHOTOS OF THE CARNAGE
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Sorry to see the damage. I can't identify what those wires/connections are for from your pics, but would recommend doing a VCDS (or equivalent) scan of your car for error codes, to determine what components or systems may have been affected.
    As far as a repellent is concerned, I've had success in stopping mice and other vermin from getting into my attic, as well as under the outdoor air conditioning unit (when it's covered for the winter months) using Fresh Cab. It's typically used for vehicles that are stored, e.g., RVs, boats, etc. But I don't see why it couldn't be used under the hood of your car, as long as it wasn't sitting on parts that get very hot, like exhaust manifolds, etc. It can also be placed in your garage or near where you park your vehicle. Here's a link to the product and more info: https://www.earthkind.com/product/fr...ent-repellent/
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Quote Originally Posted by HIDrive View Post
    While doing by oil change this evening I made a terrible discovery. The wiring harness just below the oil filter and leading towards the firewall has been munched on! Most of it still looks intact except for the outer housing and the final wire at the back has been severed! I have no idea how long it has been like this and I have yet to get any warning lights and the car seemingly runs great... Can someone please help me identify what wires/plugs these are and can just this section be repaired or replaced or is it the end of a much larger harness? I did as thorough of a search of the rest of the engine bay and everything else seems fine but no way of being 100% certain! I guess im looking for some deterrent recs too if you have them.
    See if your insurance will cover the replacement
    '18 S4 Prestige; all packages
    Junior Member One Ring
    Apr 22 2022
    Chicago
    I had this happen TWICE on my A3 in a matter of 7 months. Rats chewed thru the wiring harness to the oil level sensor. I had to have it replaced twice at about $1200 each time. After the second time, the dealership said we have a spray we can put on there to see if it deters them from chewing on them again. They offered that AFTER having the repair done twice. I was irate as to why it wasn't offered the first time. Ask your dealership what the spray is called or have them apply it. So far it has worked for me.
    Jul 18 2010
    NE Ohio
    Here are some additional deterrents (including sprays) for consideration and advice on eliminating the rodent problems.
    https://www.automasterly.com/best-ro...ents-for-cars/
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    These products seem to be based around peppermint and cinnamon scents - wonder if peppermint oil from a grocery store would have the same effect?
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
