Good evening! Could one of you wise folks inform me as to the starting position of the manifold flap prior to placing under Spring Tension?
Im FINALLY about to reassemble and seal and install a fully serviced and cleaned intake manifold and couldnt seem to find a good video or diagram on the position the flap should start on and or the sequence to best assemble under spring tension. Much obliged as always!
Freshly cleaned ports, new gaskets, throttle body, valve cover gaskets and significant grime and sludge weight reduction :) Almost there!
