    Nov 21 2012
    BC
    Jacking front of car too high causes smoking?
    This happened after doing some boost leak testing and I'm wondering if running the car with the front jacked up can cause the car to burn blue smoke when revved, due to turbos not being able to drain properly?
    Sent from my motorola one 5G ace using Tapatalk
    2000 S4 - Daily
    1989 MR2 Supercharged (Turboed)
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Def not.
    Never happened to me but maybe you pushed some oil during the boost leak which is burning off. If it doesn’t go away you got something else going on.
    Nov 21 2012
    BC
    Quote Originally Posted by Silverex View Post
    Def not.
    Damn, ok. Not looking good.
    The first few times pressurizing the system I forgot to cap the y at the pancake valve and didn't remove the oil cap - what could cause oil burning then? Only thing I can think of is turbo oil seals but can they get damaged this way? Btw I couldn't build more than 5psi (give or take a couple psi) due to boost leaks during this time.
    2000 S4 - Daily
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    Boost leak testing within your operating range is safe. I usually just do 15 cuz those things can pop off.
    I'm not sure that I would even hear a boost leak at 5.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    You pressurized your crank case by not disconnecting your pcv and leaving the cap on. Just drive it until you burn the off.
