Results 1 to 10 of 10
    Junior Member One Ring
    Apr 05 2019
    Georgia
    P0507, P1297, P2279 A4 B7
    Hi
    Last week idle was a little bit rough, CEL came on
    001287 - Idle Control System RPM
    P0507 - 001 - Higher than Expected. - Intermittent
    I replaced PCV and the two corrugated breather tubes that were quite brittle.
    Deleted code
    Short test drive with no issues.
    Next day after engine at temperature CEL is back on, very rough idle, much worse than before.
    3 Faults Found:
    P0507 - 001 - Higher than Expected. – Intermittent
    004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 001 -
    008825 - Leak in Air Intake System
    P2279 - 002 - - MIL ON
    If I remove the breather tube from the manifold port and put my thumb on it engine runs fine.
    Any advice is highly appreciated.
    Sep 27 2019
    Milford, PA
    What year is your B7? I had a very similar issue with the same codes on my 2008 not too long ago. For me, it turned out the check valve in the tube connecting the valve cover to the compressor housing (I believe) was busted. I am not positive, but I thought I read that earlier models do not have this check valve, while late models do. Might be worth checking out.
    Apr 05 2019
    Georgia
    Thank you mbruveris12
    It's a 2006. I don't know if it has the check valve, but I'll find out.
    Appreciate it.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    Quote Originally Posted by mnet View Post
    Appreciate it.
    It has it, but its in the PCV instead of the rear breather. Early model(R revision) PCV has this extra check valve in the PCV unit.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Apr 05 2019
    Georgia
    Thanks Jayz691
    it's a late 2006 and the part# on the PCV unit ends with "P" . Does that make a difference? I did not have a chance yet to look under hood.
    Feb 15 2016
    Cambridge,Ontario
    Neither have an " extra" check valve. Early models it is in the PCV not the breather tube, later models they moved it to the breather tube and took it out of the PCV.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Apr 05 2019
    Georgia
    Thank you Iceman
    new breather pipe is ordered. Hopefully that will bring her back to life.
    Apr 05 2019
    Georgia
    Hey Y’all
    turns out mine has a check valve in the breather pipe and yes the membrane was ripped. Replaced it an she is running again. 50 miles on no fault code so far. Idle still seems a little rough but much much better than before.
    Thank you everybody for your help and especially mbruveris12 for pointing me in the right direction.
    Jan 21 2018
    frackville, pa US
    Yes, I just call it an "extra" cuz they moved it. So in the R revision pcv, the valve itself has an extra check valve.. Scemantics?? Wow, lol.
    Jan 21 2018
    frackville, pa US
    Hey Y’all
    Thank you everybody for their help and especially mbruveris12 for pointing me in the right direction.
    So someone updated yours. Long as its in one or the other.
