Results 1 to 12 of 12
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    What's the best aftermarket clutch for a K04 car?
    Just curious...I read a bunch of threads and couldn't find any clear answer (maybe because there isn't one), but what is everyone's opinion on the best aftermarket clutch for a K04 car?
    Trying to retain the stock clutch feel as much as possible, so nothing with a really heavy clutch pedal and the dual-mass flywheel must also be retained.
    May 12 2017
    Heard too many horror stories about South Bend. EMD Auto, a reputable shop here in So Cal seems to recommend Sachs. I'm going to give them a try when I need to upgrade my clutch. I was originally going to go with JHM but decided against using a LWFW.
    I believe some people are running Spec without issue. But Sachs seems to be the most OEM like from what I've read so if that's what you're going for, might want to look into their clutches.
    AKA: hcuorG
    Sep 28 2014
    NY/NJ metro area
    Quote Originally Posted by Grouch View Post
    Okay, thanks. But can a Sachs clutch handle the extra power? I'm not too familiar with Sachs, so I'm not sure how many different options they offer.
    May 12 2017
    Quote Originally Posted by RockJGC View Post
    Says their standard clutch can handle up to 550+Nm. Should be enough for K04 power.
    AKA: hcuorG
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    Sachs performance clutch
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Sep 28 2014
    NY/NJ metro area
    Quote Originally Posted by A4B8 2.0tfsi View Post
    I see in your signature that you have one. Did you keep the dual mass flywheel? And how is the pedal? Stiffer than stock by much?
    May 09 2012
    Virginia
    Weighing in on this. Having owned 3 cars with southbend clutches I can absolutely say that when installed correctly they are as good as any in the industry. That being said for the B8 platform Sachs seems to have gotten it right.
    Nov 02 2017
    Sweden
    Sachs performance clutch and Sachs performance dual mass flywheel. Obviously a bit stiffer pedal then stock, but having 360 hp comes with that. No issues with that, and not tiring for commuting or city traffic. Don't even touch the gas pedal when I'm in tight traffic.
    Oct 18 2021
    Anaheim
    What’s the part # for the clutch kit/flywheel?
    Oct 18 2021
    Anaheim
    Part #’s
    And vendor used? Is this the one that’s rated at 405 toque
    Nov 02 2017
    Sweden
    Yes they only have one performance clutch for my car 550 Nm and the cheapest price on Ebay or Amazon, don't remember which one.
    May 12 2017
    Quote Originally Posted by GATO88 View Post
    Part #’s
    You can buy from them direct. My engine code is CAED so I believe it's this one.
    AKA: hcuorG
