Results 1 to 8 of 8
    Aug 07 2022
    Eagle, Co
    best place to buy gaskets, O-rings etc. for engine rebuild
    As the title says, is there a one-stop shop out there to pick up OEM or equivalent engine sealing kits?
    Also hoses and electrical connectors.
    Thanks
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I like Europaparts. They once stashed a bunch of parts under a pallet for me so I could pick them up on my way home from the beach in the middle of the night.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Heads up that for most of the seals on this engine you are going to end up buying them separately (not really such thing as a 'head gasket kit' or the like, unless ECS or someone put their own together).
    For OE parts (dealer source), I used to use AudiUSAParts.com (had very good prices and didn't charge tax), but more recently it looks like GenuineAudiParts.com has better prices.
    For non-dealer stuff pretty much always FCP or ECS. Occasionally eBay.
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    FCP Euro, it’s the warranty.
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Since they are cheap definitely buy spares they will come in handy later down road
    May 10 2018
    MA
    Quote Originally Posted by CELison View Post
    Second these guys, or form a good relationship with your local parts department. I’ve used EP since they opened, for stuff I couldn’t quickly source on my own, as they maintain good stock levels of actual original Audi parts.
    Senior Member Two Rings PoVolks's Avatar
    May 12 2009
    15' Q5 TDI, 09' RS125, 04' GLI for $1k
    Atlanta, GA
    Quote Originally Posted by ShelbyM3 View Post
    x2. If you botch a seal install, or spring a leak or a part fails, fcp no hassle lifetime warranty is pretty rad. They don't have everything unfortunately. (i.e. Mahle rings)
    Sent from my Pixel 4a (5G) using Audizine Forum mobile app
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Audi Dealer.
    I would go genuine audi parts for gaskets, o rings , seals ect.
    If not
    FCP euro
    Victor Reinz, or rein
    Cheers
