Results 1 to 13 of 13
    Established Member Two Rings BaggedB9S4's Avatar
    Nov 16 2020
    Arizona
    Brake pads premature wear
    While driving to work this morning I received an error for brake wear. My S4 has just over 17k miles on it so I was a bit surprised. I heard about quick wear but this seems excessive. From what I can see, with the wheels still on, the rear pads look fairly low but the front pads don’t look too bad. When I drove home however the warning was gone and did not come back. I was curious on what other people were seeing for mileage and also what pads are suggested. I was looking at EBC redstuff but can not find front and rear in stock. I’ll probably just pad slap them since the rotors look perfect, I know it’s not the best move but I’m getting married next week and can’t spend my money on shiny new car parts… from what I’m being told 😅
    Feb 02 2021
    San Diego
    That's about right for the rear pads sorry to be the one to break it to you :)
    Nov 16 2020
    Arizona
    Quote Originally Posted by Sebastian Tu View Post
    It just seems odd to me, like the brake bias isn’t correct or the rear pads are a different compound. The dust has been horrible so I guess that’s something to look forward to mitigating
    Feb 02 2021
    San Diego
    All b9 friends of mine (and myself) have seen about 15k out of the rear pads and roughly double that out of the fronts. Guess I can't really speak to why but it's different loads, different sizes, so I don't expect them to be the same wear. I got hawk 5.0's and the feel is different, some good some bad, but the dust is wayyyy less
    Junior Member Two Rings
    Nov 13 2019
    MA
    I purchased my S4 with 20k on it a few years ago. When looking at the Carfax I noticed rear pads had been done at 16K and I was surprised to see that. I would recommend turning off pre-sense which I noticed was applying rear brakes in various driving situations. These cars have way too many electronic Nanny’s for people that I guess can’t drive without assistance.
    Aug 12 2021
    FL
    How is the bite and squeal on those 5.0’s? Thanks
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    '18 S4 Prestige; all packages
    Nov 16 2020
    Arizona
    Quote Originally Posted by SHCKR View Post
    Thanks for that link, great info there! Centric posi-quiet seems like a good move for now. What is the best scan tool to tackle a simple job like this? something like this? https://www.amazon.com/OBDeleven-Blu...-3-spons&psc=1
    Feb 02 2021
    San Diego
    Quote Originally Posted by flee View Post
    The initial bite is much less as the operating temp is higher than stock pads. There's a bit of squeal sometimes but not too bad. I can definitely lay into the brakes harder when driving aggressively and they're much more linear in pressure. Big fan. Also much less dust
    Nov 16 2020
    Arizona
    Just curious if anyone has tried this method to retract the rear calipers? Seems easy. see 2:50
    https://www.youtube.com/watch?v=_jMR5Jygsb8
    Dec 21 2017
    montreal, Quebec
    I had a friend that used this method on his rear brakes on a b8 s4. Said it was easy…
    Not cleaning/greasing the pins? Not sure I agree with that…
    Nov 16 2020
    Arizona
    Changed them today with that method, worked great! I also didn’t realize you only need 2 wear sensors and not 4. Trying the centric posi-quiet pads out, so far they feel great. A couple of squeaks while bedding them in but those should go away
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Quote Originally Posted by BaggedB9S4 View Post
    Yeah I bought 4 sensors as well, but for like $2 each who cares
