Results 1 to 19 of 19
    Oct 26 2015
    Norman/OK
    Who has info on drop in B9 S4 rear subwoofer upgrade
    Is there a upgrade for the dismal rear subwoofer in the B9 S4? I have the B&O system and that sub sucks. Looking for something that will drop in and possibly work with the stock amp if possible 1st before I go to looking for a while new setup as an option.
    Senior Member Three Rings angrycatmeow's Avatar
    Jan 22 2022
    FL, US
    I think there's a thread over on audiworld
    Sent from my SM-F936U1 using Tapatalk
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Quote Originally Posted by TJay74 View Post
    @Bobby Kinstle
    '18 S4 Prestige; all packages
    Oct 03 2020
    San Diego/CA/USA
    Subwoofer is a 10 or 12 inch 8 ohm dual voice coil. A recommended subwoofer is the kicker compC series. I’d rather fab a box and put a higher quality subwoofer and amp combo.
    Oct 26 2015
    Norman/OK
    Quote Originally Posted by spacecase View Post
    Im 48, not interested at all in a box or separate amp. I value trunk space over having an enclosure in my trunk.
    Senior Member Four Rings
    Nov 20 2021
    United Kingdom
    You can get pre-made boxes that fit into the cubby holes in the side of the trunk that don’t take up any additional space. It makes a big difference in terms of sound quality.
    Aug 12 2021
    FL
    Lol I’m 51 yet live and drive like I’m 30.. and tried the drop in Kicker and sounded like poop.
    Did a small single cheap box with mono amp and sounds great.
    Also advise to Dynamat as much of that tray as possible. I did under rear seat, tray, trunk and battery area.
    Just my old .02
    Good luck either way you go!
    Senior Member Two Rings Jetta03's Avatar
    Jan 29 2020
    Went with the kicker 44CWCD104 myself within about a month of buying the car :). No box, works with oem amp, fits fine under the rear shelf, and is a noticeable improvement over oem. I also put dynamat over the rear shelf while I was in there.
    Cheers
    Oct 03 2020
    San Diego/CA/USA
    It’ll be better than stock, but far from a quality subwoofer. Im not sure what age has to do with it. I’d rather buy the a4 rear trunk box and put a W6v4 in there and amps are very easy to install due to our battery location (trunk). Quality has no age limit and once you’ve had quality hi-fi speakers in a car it’s hard not to have it.
    Jan 29 2020
    Super. And an RS4 is much better than an S4. In fact an RS6 is better than each of these. Why are you driving an inferior S4?
    Oct 03 2020
    San Diego/CA/USA
    Quote Originally Posted by Jetta03 View Post
    Because a RS4 isn't availablein the US but I do plan on getting one if they ever release one in avant form here. Not sure where you're getting at or trying to be combative? I also had that exact kicker subwoofer installed in my last audi and it was better, but not what I was after. an infinite baffle subwoofer is not going to sound great compared to a sealed box, especially with a subwoofer not really designed to be an infinite baffle. If your goal is to have a marginally better sounding subwoofer the kicker is fine, but there are other solutions that's about the same work as to swap out your rear deck subwoofer.
    OP if you get the kicker, order a 10inch MDF ring as it helps mount the subwoofer easier to the rear deck. I have a few lying around if you end up needing one.
    Jan 29 2020
    Goals, now you've got it. I believe the OP expressed his at the top of this thread.
    Jul 31 2021
    Carrollton
    I'm 43 , here is my drop in sub :)
    Nov 20 2021
    United Kingdom
    Quote Originally Posted by haveyoumetjeff View Post
    Hahah, no fucking around. I love it!
    Oct 03 2020
    San Diego/CA/USA
    Very clean. what subwoofers are you runnning?
    Sep 12 2021
    North Houston Texas
    I have two first place trophies in the advanced category in IASCA from my younger years. I've been holding off upgrading the same BO sub...but I'm getting close. I just don't want to lose trunk space.
    Veteran Member Three Rings Bobby Kinstle's Avatar
    May 16 2019
    2019 Subaru Ascent
    Livermore, CA
    Here you go:
    https://www.audiworld.com/forums/s4-...e-b-o-2972479/
    It helps. Some will feel it's enough (give it time to break in) and some will want more. A boxed sub will always be better but the basser compartment subs are all sealed boxes, need and amp and won't play much below 40hz. I was happy with the amount of bass but I added an amp because I wanted to change the crossover frequency.
    Dynamat the entire rear deck and seal EVERY opening on the bottom that isn't the subwoofer and that helps A LOT
    Jul 31 2021
    Carrollton
    There are 2 12w3's in there with a side port on the passenger side.
    Have a JL XD600 running them. I love it, can actually feel them
    Also have a JL VX600/6 running focal 165k3 3ways up front. They are a little bright for me but 100x times better than Stock
    Oct 03 2020
    San Diego/CA/USA
    Nice setup, I really like JL and Focal setups. I used to run a 12w6 on the Slash 500.1 and the Focal AS165 on the Alpine PDX amp. Have you thought of swapping the tweeters? My focal tweeters were a little bright. My buddy gave me some leftover Hybrid Audio tweeters and they made the sound much more warm and balanced. If you think your speakers are a little too bright, I recommend swapping out the tweeters to see if that helps.
