Originally Posted by
oesman
The stickers on the door will allow you to carry the maximum payload possible in the car. The owner's manual has pressures dependent on tire/wheel size which will give better performance vs. max load.
And to add to this before someone says the sidewall of the tire says 55psi. The pressure listed on the sidewall of the tire is the max PSI for the max load rating of that tire. So if a particular tire has a 1750lb load rating, then times 4 that means the set of 4 tires can handle 7000lbs. Once you subtract out the curb weight of the vehicle and the normal occupants the remaining difference is the cargo weight that Audi certifies the vehicle to be capable of hauling.
I am running the Michelin Pilot Sport All Season 4 tires on my B9 S4, I run them at the 41psi front and 42psi rear setting from the door car, most of the time it is only me in the car. I like a firmer ride so that works for me, with that as said read the manual as it gives you the weight ranges and suggested tire pressures for the weight you will be at. You can use that as a starting point.
