Results 1 to 8 of 8
    Nov 13 2009
    the OC, SOCAL
    jacking point in front of the car. has anyone tried doing it at the front subfram?
    i was just thinking, is the front subframe strong enough to jack up the front of the car so that we can put jack stands under it?
    has anyone tried it yet or is it just theory that it wouldn't take the weight for lifting?
    Dec 07 2021
    Columbia, MD
    Quote Originally Posted by 949 View Post
    Use the pinch weld and then put a cloth on your jack stand to stop from it getting all knarly.
    Nov 13 2009
    the OC, SOCAL
    that seems to be an answer to something else.
    let me clarify.
    has anyone used the subframe to lift the front of the car before?
    Junior Member Two Rings RUIZRUIZDIEGO's Avatar
    Mar 18 2018
    01 B5 S4,16 A3 E-tron
    Hawthorne California
    All the time bro.
    Just make sure to not go metal to metal
    2016 Audi S3 Prestige in Mythos Black
    Rays CE28N 18"*9.5" wheels, Michelin Pilot Sport 4S Tires, Billstein B16 PSS10 Coilovers, H&R rear and front Swaybars, APR HPFP, APR Catchcan, APR turbo inlet, Air to Water Intercooled.
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by RUIZRUIZDIEGO View Post
    All the time bro.
    not sure if your joking. but if you are serious, is there a specific location that you recommend and are you using some sort of 2x4 or something else to disperse the weight?
    have you seen any damage or bending of the subframe or the connection points?
    FYI, my goal is to lift it there and then put jack stands on both pinch welds on the sides. then remove the jack. it wouldn't be there for the entire time im working on the car.
    Oct 30 2022
    los angeles/CA
    I use pinch weld to jack up and put a jack stand just under between lower control arm and frame. And, I jack up another side, using the pinch weld or vice versa.
    When I lift my car completely off the floor, I first jack up from front driver side and put a stand under lower control arm and put a stand under the pinch weld of rear driver side. And, I repeat this way on the other side.
    Junior Member Two Rings Thejacobhood's Avatar
    Nov 28 2019
    Indiana
    I use the rubber pinch weld tool flipped over on my jack and jack from the subframe with no issue.
    Mar 18 2018
    Yea no just dont mar up the aluminum sub. Put in a 2/4 near on center and just enough to get the forks from the lift under the car sometimes. ONLY ON MY CAR haha
