Results 1 to 7 of 7
    Mar 08 2021
    Detroit
    Qs about buying a Q7 for towing
    Hey all, looking to buy a 4L Q7 to tow my S4 to the track. From what I've read, air suspension makes a world of difference and includes some automatic weight distribution functionality. My problem is when reading through the various classifieds, I can't find really any with air suspension, or at least not mentioned in the ad.
    Questions.
    Is the tow package or air suspension standard in any trim? Or are they both a purely a la carte?
    I've only been looking at 3.0Ts, are these options more common on diesels? A specific trim of diesels?
    I've seen video of a Q7 with an electronically controlled hitch, was this offered only during certain years? Can it be retrofitted?
    Can all Q7s with Air Suspension be identified by the switch in the right rear of the vehicle? Or was this relocated in any year?
    Lastly, does anyone know the PR codes for the two package & air suspension?
    Thanks fellas!
    Senior Member Three Rings angrycatmeow's Avatar
    Jan 22 2022
    FL, US
    Air suspension is part of the Adaptive Chassis package. PR code 1BK for 4 corner air suspension, according to my build sticker and the decoder on planetvag.com
    Edit: just saw you're talking about a 4L not 4M. Maybe the same?
    Sent from my SM-F936U1 using Tapatalk
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    No, it was an option on S line Prestige. 1BK.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Mar 08 2021
    Detroit
    Quote Originally Posted by angrycatmeow View Post
    Thanks. Adaptive Chassis may be a recent package, but the PR code seems correct. Although maybe 2MB also.
    https://static.nhtsa.gov/odi/tsbs/20...66878-6903.pdf
    Mar 08 2021
    Detroit
    Quote Originally Posted by q5 dave View Post
    So only available to S Line Prestige? That should help narrow my search.
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Yes correct
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    It was actually a stand alone option, even prestige models had to option it. S-Line was not a requirement to get air. Typically it came on higher optioned models such as the S-Line but you could order air with none S-Line cars.
    Electronic hitches are a euro only option and does not apply to NA cars. Visually the only hint of air is the aforementioned switch in the boot area on the right.
    The car can be retro fitted with a factory hitch but the factory installed hitches came with a larger fan for higher cooling capacity and the 4pin connector in the car comes with an extra brake pin activated. Having the factory towing will also allow the backup radar to be disabled when tow mode is enabled. It will also disable side alert when towing so that the car doesn't think something is in your blind spot.
    All in I'd say keep searching as they're fairly rare but they are out there.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
