Okay everyone, I’m going to start at the beginning to give some background here.
One day a few weeks bsck it hit around 30 degrees F where I live, which was the first of the season. I’ve only had this car during the summer so it was the first time of the year it’s been this cold with the Audi b8. I was in a drive through line, and noticed it started rumbling and my RPMs starting frantically moving from 700-1000 back and forth until I put it in park. I was worried it could have been the spark plugs so the next day I went out and changed those. There was oil in the tube area on the top of the plug, and the bottom of the plug was ashy white.
A day later, my check engine light comes for the first time on saying im Running too rich bank 1. I thought maybe I didn’t torque the plugs in correctly so I took them out and they were black and fouled already. The old ones never looked that black.
So since I saw some oil in the tubes and knew of an oil leak on my valve cover, I decided to change the whole valve cover gasket and gasket near spark plug tubing. After that it was running good for the most part, and the CEL turned off. I changed my oil a few days later because all of the pieces of gasket material that got stuck in the cam shaft area I wanted to clean that out. When turning the car on after switching the oil, the rpm’s started fluctuating like crazy again for a few minutes. I was guessifn maybe there was some lodged gasket material that I moved out into the filter or something.
So I get on the highway later that day and while accerating hard my car started jerking, almost felt like a failing transmission shifting jerk and the cel went on.
When I got home to read it, it says Air intake system leak and the fuel to rich bank 1 again. What is going on???
I reset it again to see if it would come back but has not yet, however accelerating hard (past 2.5k rpm starts the jerking)
I almost thought it was detonation at one point, and my gas mileage has been significantly worse as well. It idles and drives at low speeds great.
Oh, I also put new plugs in again during the cover replacement, and cleaned the MAF to see if that was the problem.
Anyone else experience this or know a common fault? I don’t have a OBD 2 reader that can read data at the moment, but hopefully I will by the end of the week.
There is no visible leaks from vacuum lines or anything, and the air filter was recently changed. I put everything back together as I should with all torque specs completed right.
