Everyone has been asking for quite a while, what can a TTE710/TTE810 SQ5 really do when it came to the 1/4 mile, 0-60...
I’ve spent months running stage 2+, including running a world record on the stock turbo, and was left wanting for more! I had a TTE810 sitting in my garage, so I pulled the trigger.
My SQ5 has been in development for some time with Integrated Engineering. The TTE810 tune will be available soon, and is right around the corner😉 Currently in BETA! There’s more to be had from the turbo itself/entire setup. It has completely transformed my SQ5, there’s no going back.
Last week I was able to take my beast of an SQ5 to my local drag strip and run these INSANE NUMBERS!! Yeah, you guessed it, SQ5’s were running 11’s.. now we’re doing LOW 10’s!?
1/4 Drag Strip | Pacific Raceways
All runs were at approximately @1500DA average
RUN #1 10.69s @130mph
RUN# 2 10.41s 131mph
RUN #3 10.42s @131
Check my video out below to see what this monster of an SUV ran… 😉🚀🔥
You can also check out my other videos on how to install the TTE810, tune your ecu, how to drag prep your B9 S4/S5/SQ5, and even reviews on the performance of such modifications.
Stock internals, stock motor, stock axles, stock transmission, just supporting bolts on and tune!
Full weight/street performance/dyno testing is all coming!! Subscribe for more! This is not the end.. ONLY THE BEGINNING 💥👀
Other Special Thanks:
TheTurboEngineers
CTS Turbo
JXB Performance
Turbosmart
034Motorsport
Forged Fuels
For providing amazing supporting hardware in my quest!
2018 Audi SQ5
IE ECU+TCU (Stage 3 E70 BETA)
IE Intake
IE Turbo Inlet
IE FDS Intercooler
CTS Catless Downpipe
APR HPFP
RS6 Injectors
TTE 4 Bar Map Sensors
TTE810 Hybrid Turbo
ECS Res-Delete
034 Front Strut Brace
034 Street Density Engine Mounts
034 Front/Rear Sway Bars+Billet End Links
034 Billet Subframe Inserts
034 Transmission Mount/Billet Insert
034 Diff Inserts
034 Front/Rear Lightweight Rotors
JXB Driveshaft Brace (Street)
KW V3 Coil Overs
Drag setup:
FC04’s + 245/45/17 Hoosier DR2’s
Kirkey Seat (Drivers)
Passenger and Rear Seats Out
Engine cover off 😉
My channel: Need4Built
I have a TON of other content specifically for the B9 SQ5! Check it out!
Link to World Record SQ5 Runs:
https://youtu.be/7h6ieLnIxlc
