As title says, I have the following parts for sale:
Integrated engineering 80mm throttle bottle ( brand new, only test fitted) -$550
Meth plate for throttle bosy ( allows meth injector to be easily inserted into plate attached at throttle body)
Used Aem Meth boost controller( does not inlcude all wiring) [https://www.maperformance.com/produc...C0u4QAvD_BwE]- $85
Evo series Boost gauge and b8 steering column mount ( no wiring)-$ [https://www.ecstuning.com/b-prosport...vobo.psi~psp/] -$40
Brembo 18z 6pot front brakes. direct bolt on for b6/b7 platform, not sure about b8. comes with slightly used drilled and slotted 345mm rotors. ( brake fluid got on the caliper and took off some of the paint ( bronze powder coat) -$550
I have spare engine sitting down for parts ( 99k on motor) ( hydro locked from leaking supercharger intercoolers) . Never took it apart to see if reusable ( i just replaced to newer engine) ... pick it up for cheap ( fairfield ct)
I also have a set of 19inch Black Diamond bd3 gun metal rims for sale : slight curb $500 gets them ( http://www.wheelstreetonline.com/mm5...oduct_Code=bd3)
im not on this that often but you can dm me or email : [email protected]
