Looking to see if anyone has a diagnosis suggestions, similar experience, or can recommend a shop in Connecticut who could work on this sort of car?
History:
2014
A6
TDI
225,000 Miles
Owned car since new.
All factory recommended services performed. New battery Jan 2021.
Fuel, air, cabin, oil filters all regularly and recently changed.
Diesel gate scandal modifications performed at 82K miles. Nothing significant to report from the modifications.
MPG has not changed with recent leaks and CEL.
Never overheated the car.
No milky/foam on oil fill cap.
Oil change oil appears (visibly) to be the same as always.
Symptoms:
1. Oil leak: Smells like a leaky EGR or PCV type smell (I have no clue if this thing even has an EGR or PCV) smoke/oil, not necessarily burnt oil. It does not smell like oil dripping on a hot exhaust. I use less than ½ a quart of oil between changes (5k mile)
2. Coolant leak seems more aggressive. I have had to add coolant every few thousand miles. It gets below the “min” line, but not enough to trip a warning light.
3. Oil in coolant. Coolant is no longer pink. Coolant has black/oily film to it.
4. CEL: 17561 - NOx Sensor 2 Bank 1 P229F 00 [237] - Implausible Signal
MIL ON
Took the car to a local independent shop highly recommended by coworkers with late model M series BMWs.
Independent shop diagnosis:
Rear main seal leaking.
Flushed coolant 3 times and still coolant still appears “oily”
Pressurized coolant, no visible leaking but pressure dropped.
They suspect a bad head gasket but didn’t have the tools to do a compression test.
Rational:
1. No visible coolant leaking as pressure dropped.
2. NOX sensor could be getting contaminated by coolant/oil downstream.
3. Oil in coolant
I tried 2 other independent shops who didn’t even want to touch the car!
So again has anyone experienced anything similar? Or can you recommend a place in Connecticut who would be able to work on this car.
Thanks
Matt
