Results 1 to 3 of 3
Thread: P3262 code?!
    Oct 14 2006
    by the lakeshore, mi
    P3262 code?!
    I finally got around to take a look at my avant to figure out the P3262 code.
    I took a look at both down stream O2 sensors where they connect into the cats and followed each wires which goes where they are suppose to go, meaning the pass side goes to the pass side of the engine bay and the driver side goes to the driver side of the engine bay. But I can't find the other end where they connect to in the engine bay?
    While I was looking underneath my avant I noticed that I'm missing the rubber snub mount.
    I know that you can but a upgraded snub mount with a new bracket but I wasn't able to find the bracket for the 2.8 and wondering if the bracket from the 2.7 will fit?
    I also noticed this pipe is crusty and I'm guessing that this is coolant leaking?
    Anyone have a part number for this fender seal (the long straight one)?
    What is this little rectangle with single wire thing for?
    How important is it to have the belly pan?
    Current: 01 A4QM avant daily driver.
    Past: 92 ABZ 100CSQM avant, 97 A6Q avant, 93 S4, 95.5 avant, 93 S4, 91 10vt CQ, 98.5 SC'd & IC'd A4QM sedan.
    Jun 05 2019
    95.5 UrS6 avant; 16 SQ5 (wife’s); 89 Jetta ; 90 Quattro V8(sold); 07 MDX; 85 Magna
    SE Pa
    The oxygen sensors are clipped into brackets on the front of the false firewall. I think the driver side is black and the passenger side is brown
    Oct 14 2006
    Quote Originally Posted by mk2_madness View Post
    Thanks for the info. When I get a chance again I will take a look at it.
