Hi guys.. already cleaned up all drains.. can pour water into the channels and see water coming out trough the four drain holes. The rear part of the glass is no aligned in height with the roof.. like 2 mm so I believe that theres so much water coming in that gets out of the channel and into the headliner.. if pour a lot of water into the channel I can see it on the headliner .. is there supposed to be a seal between the sunroof structure and the roof.. already took out the glass and tried to align it wit the roof but when I open it an close it it will always sit a little lower on the rear side..(the height and position with the 6 screws of the glass) gettin crazy her will take some pics when Im back home..
