I currently have a cheap maxspeedingrods turbo installed (specs below), cat back exhaust, pod filter.
My question is how much would performance improve (if any) by adding a FMIC?
It's currently at stock boost, how much is a safe level to increase it to? And what's the best method to increase it?
Compressor :
Wheel Diameter: 50/37.5 mm
Trim: 56
Compressor Inlet: 44.5 mm
Compressor Outlet: 50 mm
Blades: 4 x 4 blades type
Turbine :
Wheel Diameter: 46/42 mm
Trim: 83.7
Blades: 12 blades
Inlet Flange: 3 Bolt Flange
Outlet Flange: 3 Bolt Flange
Turbo Model: k03 upgraded, K03S
Engine: AEB/ANB/APU/AWT/AVJ/BEX
Fuel: Gasoline
Cooling Type:Water & Oil Cooling
Horsepower Rating: up to 220 HP
Bearing Type: Floating Bearing
Thrust bearings: 270 Degrees
Turbo Type:Individual
Universal Fitment: No
Finish: Polished
Condition: Brand New
Accessories: You will get exactly as shown in the picture above
Package Weight:5750g
Package Size:26*25*23cm
