Results 1 to 4 of 4
Thread: coil overs
    Oct 27 2006
    Currently only S4
    Fort Walton Beach FL
    coil overs
    I installed PSS9 on my car in 2007, about 100,000 miles ago. I need to replace now and have narrowed down to replacing with PSS9s or XT SA coil overs. Does anyone have any insight on the XT SA? I believe the PSS9 are better, but are they that much better. It is for street driving, not planning any track, anymore. Thanks.
    https://www.ecstuning.com/b-suspensi...g/18210032~st/
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    That is essentially a KW unit---less the stainless steel strut body....
    Why not look at the KW V1, They are similar in price...
    https://etspec.com/kw-v1-coilover-kit-for-b5-s4
    I have these on my B5 S4 and find them excellent for street driving and they work good for casual track use (needs more rear spring)
    FWIW- I have these set at 13-1/2 inches from the center of the wheel to the fender lip(18" rims w/225x40 PS4S)
    Oct 27 2006
    Currently only S4
    Thank you. I'll check them out.
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    If you want a little stiffer rear spring, check out Vogtland GT3 coilovers. German company.
    // 2001.5 Pearl White B5 S4 Sedan 6MT
