OK, search threads, but no exact one for this issue (?!?)
I can't release trunk from driver's door, nor remote key fob, nor from the trunk switch. I don't hear the actuator pulsing at all.
I manually release trunk by crawling inside. I removed the trunk cover from inside face of trunk lid. I removed feeding connector to release solenoid and put volt meter on every combo of the 3 wires and hit my trunk release on key fob. NO voltage readings at all.
So, questions:
- is there a fuse or relay for this function ? (searches online for fuse line ups only show Allroad rear hatch power mechanism).
- Also, on my 2015, it looks like the solenoid and release mechanism are ALL ONE assembly. Audi dealer parts dept showed same on parts blow up. Whole assy is $ 153.
thanks.
