Results 1 to 9 of 9
    Sep 01 2012
    Edmonton
    racingline propshaft bearing alignment torque specs
    Any chance anyone knows the torque specs for install on the racingline propshaft bearing alignment? No instructions on torque specs, I emailed racingline but no reply.
    Side note where is the best place to acquire service repair manuals? Any free pdf downloads anyone has stumbled upon?
    Thanks
    Sent from my SM-G970W using Audizine Forum mobile app
    2018 RS3 Panther Black
    Oct 06 2019
    Portugal
    Could you please make a review/tell your opinion on this kit after testing it?
    Sep 01 2012
    Edmonton
    Quote Originally Posted by B5M3W5d View Post
    Will do.
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    https://erwin.audi.com/erwin/showHome.do
    Quote Originally Posted by WAF View Post
    Thanks
    2020 TT- RS
    ex 2018 TTS
    Sep 01 2012
    Edmonton
    Quote Originally Posted by kevin#34 View Post
    I checked that site you referred, but I didn't see any rs3 specific manuals.
    Aug 11 2019
    Rome, Italy
    you need to subscribe, to access and download the manuals
    2020 TT- RS
    ex 2018 TTS
    Nov 11 2021
    Atlanta, GA
    Thanks
    For the OEM driveshaft install, all the bolts that go through flexible discs at the ends of the driveshaft into the bevel gear, driveshaft or rear final drive unit are 50 Nm and then another 90 degree turn, and they are one time use fasteners.
    Bolts for the driveshaft intermediate bearing support frame are 20 Nm and then another 90 degree turn. They are one time use fasteners as well.
    Sep 01 2012
    Edmonton
    Quote Originally Posted by TToysRuS View Post
    Thanks for the info from other installs I've done there's been usually a final degree turn added. Racingline got back to me with 19nm and no 90 deg final turn.
    Nov 11 2021
    Atlanta, GA
    Welcome!
