Results 1 to 3 of 3
Thread: Oil cooler
    Feb 23 2022
    Montenegro
    Oil cooler
    So I am getting bigger intercooler these days,and when I remove the oem Ic I want to buy a oil cooler that fits the factory dimensions.Could anyone reccomend me some oil cooler in Europe.OEM SIZES ONLY.
    Послато са SM-G960F помоћу Тапатока
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    S4/V6 oil cooler. You need the longer shaft(and housing if buying used , its cheaper) from 1.9 TDi / buy it separate(cost the same as a whole housing used). Be aware that if you do buy a 1.9 housing and you put it on to avoid unscrewing the filter screw then you need to swap the one way valve over, as the tdi's come with a choke for the turbo pressure line not a valve.
    Feb 23 2022
    Montenegro
    Quote Originally Posted by Blazius View Post
    I forgot to mention,engine is 1.8t ,does that change anything that you mention?
