Results 1 to 11 of 11
Thread: No Boost,No CEL
    Active Member One Ring JuStJPpLaY's Avatar
    Jul 11 2022
    Bulgaria
    No Boost,No CEL
    Ive read everything on forums,checked for leaks,checked turbo westgates with vacuum and removed downpipes to check gates,checked Boost pressure sensor,bypass 710n just for the test,EGT shows 0 for both sides for some reason(prob chip).Ive tested the car with vag com/odis,kts,launch.Did reset learnings for throttle etc. Cleared throttle and injectors in ultrasound and tested them if they work.Fueling is good 4bar up to 7k rpm.New sparks with coils and fuel pressure regulator.Good compression.I bought the car with the problem and can't fig it out.When it wants 600mbar it gives around 300.On 6th gear full thrtl max 160-170 km/h.No boost leaks (tested with smoke)and no boost maybe ECM cuts fueling but for what reason.What to look for .....?
    Veteran Member Three Rings TwoSnelz's Avatar
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    Have tuner check WG Duty cycle?
    Sent from my SM-G973U using Audizine Forum mobile app
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Both turbos spin freely and you're sure the TB is opening correctly? I had a dead TB that created a zero boost condition.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Jul 11 2022
    Bulgaria
    I disconnected the gates for the test so i can see does they overboost but it jumps from 300mbar to 400 or so
    Jul 11 2022
    Bulgaria
    Quote Originally Posted by CELison View Post
    No dtc for that and when i press accelerator it gives a sounds so its moving
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by JuStJPpLaY View Post
    Um, ok then.
    B9 S4- EPL/AWE
    Jul 11 2022
    Bulgaria
    I tried without exhaust just on downpipes if something is stopping gasses go tru but nothing
    Oct 15 2021
    2000 Audi S4 - Full Stage 3, 2003 VW MK4 GTI - Big Turbo / 2016 Subaru WRX Limited
    Illinois/United States
    I'm assuming you have a boost gauge. What is it at idle? should be between 15Hg and 20Hg (around -18psi) if holding vacuum properly. While driving and you punch the throttle, if the gauge jumps to zero and instantly stops then it seems likely it's an electronic controlled issue (EGT or N75). Unplug your N75 and it should boost to wastegate pressure (around 5-7psi on stock and k04 turbos); carefully watch as not to overboost if there's a wastegate issue.
    I am curious about your EGT sensors though reading zero. When they're bad, it can cause ECU to limit boost so the engine doesn't lean out too much and cause catastrophic failure. These are commonly known to go out on high mileage S4's. When I bought my S4 from a previous owner, both EGT sensors were bad and it would not boost. I left the EGT sensors screwed in but disconnected them from the plugs and connected diodes from eBay to tell ECU to ignore them.
    Feb 23 2010
    Emmaus Pa
    N75 isn't able to create zero boost if all hardware is fine. The least it can do is WG pressure.
    B9 S4- EPL/AWE
    Jul 11 2022
    Bulgaria
    Quote Originally Posted by evalegacy View Post
    Im watching it with diagnostics about the boost.The vacuum at idle is 0.6 bar thats around 8-9psi, but didn't check when i punch throttle so i will buy one tomorrow and check.When i bought the car i connected it do diag and it has EGT bank 1 fault.I though thats the reason the car is not running properly.When i get it ,i opened the sensor and i solder the pins, then the fault was gone but the car continues not to boost.I tried without MAF (rs4 installed)and with original maf for s4 and nothing,without o2 sensors nothing,without n75 same,car is running rs4 injectors too.Its 225k km and its preserved.I will check for those diodes
    Jul 11 2022
    Bulgaria
    Someone changed the original n75 to this from tt i guess.I returned back the original valve and properly installed pipes like original s4
