Results 1 to 11 of 11
    Nov 10 2018
    08 audi a4 cabriolet,'12 Prius, 87 Alfa Romeo Spider
    New york
    Rear brake rotor replacement
    Should I be able to remove old rear rotors and mount new ones without removing the caliper brackets? They look like a real pain to remove!
    Jun 17 2013
    jersey city nj
    yes
    Feb 15 2016
    Cambridge,Ontario
    i think stock is 288MM rear rotors and mine came out .. however it is very tight , your rotor will likely catch a rusted angle edge of the carrier but it will eventually come. Just dont forget to clean the edge up of rust with a small file so your new rotors pass with ease.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 17 2013
    jersey city nj
    just angle the rotor for opposite of the carrier
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by vce1232000 View Post
    yes when you do that you will immediately see the spot im talking about , just needs a little help but it will come .. sometimes it has to be dressed for the new thicker rotor to go back in due to rust build up.
    1976 Yamaha XS 360
    Jun 17 2013
    jersey city nj
    yep. i had 1 side just slip on & off with no issue. Then the other side had to grunt a little
    Mar 04 2019
    Staten Island, NY
    Will it work with having the sports suspension the same way. I’ve seen diy that show having to remove lower shock bolt.
    Rotors are the larger size 288 mm
    You a bounty hunter...Man's got to do something for a living these days......Dying aint much of a livin boy....
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    Quote Originally Posted by beefski View Post
    All the US b7's use the same rotors, 288x12mm, and yes, they slide right out. Don't work with s4 setup, gotta remove carrier with those.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Feb 15 2016
    Cambridge,Ontario
    I have sports suspension ( red shocks ) no issues
    Sent from my SM-G973W using Audizine Forum mobile app
    1976 Yamaha XS 360
    Aug 18 2020
    Sonoma, CA
    Same, easy peasy.
    Mar 04 2019
    Staten Island, NY
    Excellent.( In mr burns voice)
