Results 1 to 2 of 2
    Veteran Member Three Rings Eli0073's Avatar
    Jul 17 2020
    USA And Finland
    WCT Performance Pedal Spacer
    Always been annoyed by the distance between the brake pedal and the gas. I absolutely hate that they're not flush.
    This WCT Performance Pedal Spacer does a great job. Is it flush? Nope. Could it be thicker to make the stupid gas pedal on the DSG cars flush to the break?...Yes
    This was designed for hill and toe on the manual MK7 it just so happen to be the same gas pedal and it fits perfectly. Since my car is a Audi S3 and it's DSG I can't say if the pedal is actually flush on the manual MK7.
    Having said that, the transition between gas and break is less annoying. You still require to lift and twist your feet between gas and break. But the amount of lift you need to do is significantly less.
    So here's a quick install tutorial.
    Step #1. Remove the cover behind the Pedals. You need a 10mm socket 2 bolts. Now that is out of the way.
    Step #2. T30 and remove the only bolt holding the gas pedal. Once bolt is removed.
    Step #3 grab the gas pedal push it down and up and it will come out very easy.
    Step #4. Put the WCT Performance Pedal Spacer it only fits one way. Put the gas pedal back opposite of taking it out.
    Step #5 T30 put the bolt back and tighten it nicely. Don't over do it.
    Step #6 put the cover back and the bolts back with your 10mm socket.
    Go for a drive and enjoy.IMG_20221026_115729_01.jpgIMG_20221026_115409.jpgIMG_20221026_115731_01.jpgIMG_20221026_170303.jpgIMG_20221026_170308.jpgIMG_20221026_170333.jpgIMG_20221026_170353.jpgIMG_20221026_171023.jpg
    Sent from my IN2017 using Audizine Forum mobile app
    Jul 17 2020
    USA And Finland
    More pictures of the install with before and after.Attachment 286505Attachment 286506IMG_20221026_171424.jpgIMG_20221026_171438.jpg
