Subject: ECS Front Sway + Adj End Links
Body:
Reach out to [email protected] with questions or if your interested. Thanks
$215 · Snoqualmie, Washington
BNIB
Product Details
If you’re looking to improve the handling of your Audi B8, this is the best place to start! These cars have a lot more body roll than desired, and the stock sway bars don't quite do enough for most owners to be satisfied. Engineered, designed, and tested in-house at ECS Tuning, you know these sway bars are built to last with the highest quality.
Larger diameter sway bars have a higher torsional spring rate which helps resist excessive body roll. By eliminating the excessive body roll and changing the stiffness of the sway bars front to rear, we can improve handling characteristics by reducing understeer and keep the tire in full contact with the ground. By upgrading to the ECS Tuning Adjustable Front Sway Bar, you will experience less body roll, and an improvement to the handling characteristics of your vehicle, with virtually no sacrifice in ride quality. The sway bars are also adjustable, and allow for a “softer” setting, or a “stiffer” setting, depending on your driving preferences.
Link:
https://www.ecstuning.com/.../audi-b...022846ecs01kt/
