Results 1 to 6 of 6
Thread: Tire Rotation
    Established Member Two Rings itr0045's Avatar
    Mar 13 2019
    Shithole Portland Oregon
    Tire Rotation
    Some may mock for this question but whatever. I want to rotate the tires on my 2018 Rs5. Any issue with rotation of tires, specifically front to back that I should be aware of? Is there a sensor that will trip like on GM cars/trucks when this is performed? TIA.
    2018 RS5 Coupe
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Would suggest a reset of the TPMS after any tire rotation. Don't know of any other reason not to rotate; just make sure correct directional rotation is maintained if that shows for your tires.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Jul 16 2018
    Atlanta
    RS5 should have direct TPMS. No reason to reset it as the car reads actual pressures from the wheels. But I don't know if the system stores the set pressure by wheel location or by sensor id. If by ID and you run different pressures front/rear, yeah, you'd need to do a reset. The system may also want you to do a reset after a rotation to flag to the system "yes, wheel locations have changed". What's the owner's manual say to do?
    Veteran Member Three Rings SixShifter's Avatar
    May 29 2012
    York, Pa
    If I'm not mistaken, the 2018 RS5 does not/NOT come with TPMS ... however, TPMS is found in the 2019 model year.
    Apr 05 2012
    Earth
    Quote Originally Posted by SixShifter View Post
    Direct TPMS was optional on the 2018 model.
    Mar 13 2019
    I have this. Thanks for the replies.
    2018 RS5 Coupe
