Results 1 to 6 of 6
    Dec 27 2020
    Caliper to wheel
    My Audi dealer didn't budge and installed my winter set with this little clearance between the wheel and the caliper.
    Clearance is approximately 0.0108in ~ 0.27mm at the shortest point. To put in context, a credit card does not go through.
    Question: should I install spacers, leave it or sell the car? I don't wish to install spacers if physics say I don't have to. SQ5
    Thank you for the expert knowledge.
    Established Member Two Rings 383vett's Avatar
    Feb 15 2021
    Moraga/ca
    If they are not rubbing on turns, you are fine.
    2021 SQ5
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    You should obviously just sell the car.
    iain
    Jun 14 2012
    PDX
    Maybe
    VFF109 21x10 et30 | DWS06 295/35r21 | AWE touring resonated | AWE Intercooler | RocEuro | Cete | 034 Trans Mount | EPL stage 2 ECU/TCU | Feynlab Self Heal Ceramic | OEM black out badging
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    Caliper to wheel
    If not rubbing you might be ok but what is more important is if the center of the wheel is in correct position, if you narrow the wheelbase width you may notice SQ5 handling might change.
    Look at ET # on OEM rim and compare to winter set up, if winter rim is a higher # than OEM wheel ET# you should consider spacers.
    My winter set up with spacers is lower ET than OEM rims and handles nicely
    Dec 27 2020
    Quote Originally Posted by rcprato View Post
    Winter setup is 30 and OEM 34. I didn't notice any change on the handling.
