I recently picked up a 2001 Allroad with a misfire issue off Fb marketplace on the cheap. Previous owner had changed the coilpacks on the misfiring cylinders to no avail. So, not wanting to have to mess about with the ICM's or the coilpacks, knowing that there was a misfire issue, I just decided to order up a 2.0t conversion kit from ECS tuning and get rid of the headache all together. I followed the handy pdf instructions that came with the kit. I took out the old coil packs and ICM's and installed the new coil packs, the ICM delete cables, and the included coil pack extensions. A glorified spark plug change really, nothing to difficult. However, when I went to start my car excited to finally be free of this misfire, I was greeted with--- nothing. Just the sound of the engine turning over.
My first thought was that I fucked up, and either forgot to reconnect one of the cables or connected them in the wrong order. So I checked it over, made sure all of my cables were properly seated and that I hadn't accidently disconnected something while moving stuff around. Then I tried again with VCDS hooked up to try and see if it would throw any codes. Anything to give me an Idea of what was going on. Cleared it. Tried to crank the engine. no codes. Engine turns over, but won't start. I Googled to see if anyone else had dealt with a no start/no spark issue after installing their ICM delete, and nothing useful came up, so here I am.
I did check to verify there was no spark by pulling one of the coilpacks and spark plugs and holding it against the head to ground it while I had someone turn it over. No spark. So I finally checked the engine speed in VCDS to make sure it wasn't the crank sensor. Engine speed sensor: 120 m/sec. So now I'm stumped clearly I messed something up when installing the ICM delete kit, but try as I may, I can't find anything out of place. I did see a post that suggested the engine coolant sensor could be the issue, but usually those cause intermittent starting issues when the engine is warm, and wouldn't explain why I don't have any spark.
I'm going to go back through and uninstall the kit this weekend when I have time, and put back all the old coils and ICM's. Before I do that, I thought I would check and see if maybe anyone has any ideas that could maybe save me the headache of having to uninstall and troubleshoot more.
Here is the VCDS code list from before I cleared the codes:
Wednesday,26,October,2022,20:46:52:37711
VCDS Version: Release 22.9.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine
13 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 -
16688 - Cylinder 4
P0304 - 35-00 - Misfire Detected
16690 - Cylinder 6
P0306 - 35-00 - Misfire Detected
16534 - Oxygen (Lambda) Sensor B2 S1
P0150 - 35-10 - Malfunction in Circuit - Intermittent
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 35-00 - System too Lean
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 35-00 - System too Lean
17746 - Camshaft Position Sensor (G40)
P1338 - 35-10 - Open or Short to Plus - Intermittent
16687 - Cylinder 3
P0303 - 35-00 - Misfire Detected
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-10 - Malfunction in Circuit - Intermittent
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 35-00 - System too Lean
17546 - Fuel Trim: Bank 2 (Add)
P1138 - 35-00 - System too Lean
