After a full scan on a better OBDII reader, I am now seeing a few additional codes.
Current Codes:
01- Engine Management
P1297: Connection Charger-Throttle Valve Pressure Drop
P0172: Fuel Trim, Bank 1 System too Rich
U1113: Function Limitation Due to Received Malfunction Valve
02- Transmission
P1857: Load Signal Error Message from Engine Control
03- Brake Electronics
02214: Tire Pressure Warning - Intermittent
01314: Engine Control Module Read Trouble Codes - Intermittent
19- Diagnostic Data Interface-Gateway
03041: Energy Management Active - Intermittent
02256: Quiescent Current Upper Limit Reached - Intermittent
53- Parking Brake
464384: U1113 Function Restricted Due To Faults In Other Modules
OBDII Permanent Codes ($0A)
P0420: Catalyst System Efficiency Below Threshold Bank 1
I'm genuinely at a loss for what could be going on.
After picking my car up and cold-starting it (30 degrees F), it started immediately with a bad idle, cut out, and died. Unplugged MAF sensor and restarted, same thing. According to the place I had service my car, the spark plugs are fine. I also noticed, that after 10-15 miles of driving, I went through about 1/4th of a tank of gas. While accelerating from a stoplight, the car will sluggishly start moving and I won't get any boost until I let off the throttle and go back on it, but when I do, the turbo kicks in immediately. I'm going Wednesday to get a smoke test, but I'm fairly certain the manifold is on correctly.
I'm also wondering if it could possibly be my diverter valve, I do have an aftermarket one; however, I cleaned & installed it back on the turbo prior to putting the turbo back in. Could it causes these issues?
Other things I think it may be: Coilpack, fuel injectors, O2 sensors, PCV valve, MAP sensor???
I'm dead in the water for a few weeks since I live in a small town & the only place that works on Euro cars is booked until the 23rd and the nearest Audi dealership is 200+ miles away. Thank you all.
