Originally Posted by
Peacob
I know this is a niche topic, so I appreciate some of you chiming in.
The reason I asked this was because my timing is on one of its last few notches, so that needs to be done. I did a oil pressure test (hooked up a gauge and ran the car for a couple hours). Pressure is a hair above 1bar (Spec is 1.3).
After further reading, i'm just going to replace the balance shafts at the same time of doing the balance shafts. Hopefully that will raise my oil pressure up to 1.3+.
definitely keep us posted on this .. good for you checking oil pressure before doing timing, i bet not many do that .. i think there are a couple special tools you need for this. I would be very curious of your before and after oil pressures and what the screens look like.
We definitely know two things about this car
1. bad balance shafts can ( not the only reason of course ) cause low oil pressure on these cars
2. we are having more and more engines have the balance shafts completely seize on these engines...
it would be good to know if these are separate failure modes , or if one is a precursor to the other..
also i am not 100% sure if the clogged filter screens on these shafts are causing the low oil pressure ... or if the pressure is measured before and they seize without warning due to the fact oil pressure reads fine , but shafts themselves are getting oil starved..
all information is good information
