    Junior Member One Ring
    Oct 19 2022
    Australia
    Audi RS3 2017 DAZA clutches gone at 52,000kms is this common? Stage 2 for about 4,000
    Hi there, I was wondering I bought my car 9 months ago pre owned with 46,000kms on it I have driven it for 48,000kms and also then went Stage 2 with E85.
    At 52,000kms my clutches are hesitating changing gears at high RPM and overheating this is indicating to me the clutches are worn out. Is this common at this many KM's to be worn out?
    Dec 25 2004
    Earth
    Is the DQ500 tuned? Normally a stage 2 RS3 engine producing allot more power should also have the DSG tuned...
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Oct 19 2022
    Australia
    Yes my Stage 2 DSG is tuned as well with increased clamping pressure. Currently to get me by they have done stage 3 clamp pressure at tuners.
    May 01 2021
    Hertfordshire
    Im on 44k miles Stage 2 ECU/TCU Unitronic still on stock clutch pack, no slipping of shift issues although Im going to replace the clutch pack / flywheel soon anyway as preventive maintenance, have you tried carrying out basic settings on ODIS system ?
    TTRS 8S - Unitronic stage 2 98ron ECU / TCU, Scorpion Sports Cat, APR intake, Forge elbow, Forge intercooler, APR coils, NGK race plugs, ECE Dogbone
    10.44 @ 130mph
    Oct 19 2022
    Australia
    I am jealous! Yes I have, right now with Stage 3 clamp force it is okay but it is not hesitating but it is overheating easy. Do you have any hesitation between gear shifts sometimes? I am in the same boat so yesterday I ordered Deka Clutches so hopefully should be here in the next 4 weeks I will get them fitted and also replacing the factory DSG plastic oil tubes with Billet Aluminum ones because they prone to breaking under high HP. Also get my Mechatronic unit solenoids looked at too that push the oil around make sure it is all in good working order so i don't have to pull it out again lol
