Results 1 to 14 of 14
Thread: TPMS Question
    Junior Member Two Rings
    Nov 04 2021
    Norfolk, VA
    TPMS Question
    After I got my tired changed about 6 weeks ago everything was fine, MMI showed green for tires...today I went through a car wash and suddenly my TPMS light went off though none of my tires are low, so I reset it. Now when I go into the TPMS indicator in the MMI it only shows gray like something is missing. Anyone got any ideas?
    Sent from my SM-N986U using Audizine Forum mobile app
    Jul 16 2018
    Atlanta
    No idea. Scan for DTCs, see if anything comes up. 2013 A5 has indirect TPMS, so there are no sensors in the wheels. It presumes to guess that the tire pressure is different than what you calibrated (learned) originally based on the statistical analysis of the wheel speed sensor signal. Maybe water messed up one of the wheel speed sensors? But you should have a lot more issues on the dash than just a grayed out MMI option.
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    What year do you have? The B8 as indicated above is indirect. There is not a MMI display indicating green/gray
    2014 Estoril blue Cab Chestnut brown interior
    Nov 27 2015
    UK, West Berks
    In terms of false TPMS warnings I have had a few. I only recently noticed that in the manual it suggests resetting TPMS after every time the pressures are adjusted. I had not been doing this because the adjustments have been small. I have had false warnings sometime after tyre change or if it has been a long time since I reset the system.
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Nov 04 2021
    Norfolk, VA
    Quote Originally Posted by Neil F View Post
    Neil, it's a 2013 A5 Cab. What I mean by display is that in the MMI under car settings, before I went through a car wash the TPMS option under car settings/service & checks would show green wheels on the display. Now they are gray despite tire pressures being fine.
    Nov 04 2021
    Norfolk, VA
    Quote Originally Posted by Dippy View Post
    Yeah it went off right after leaving the car wash. Reset it, but now it doesn't indicate whether tires have pressure under the settings menu. They used to show green and whatever the low pressure one is. Now just gray as if the system disappeared. I'll hook it up to VCDS this weekend. Gotta be a fault somewhere.
    Nov 04 2021
    Norfolk, VA
    Interesting addition...it used to tell me which tire to check, lately it's just been telling me check all four tires.
    Nov 04 2021
    Norfolk, VA
    Resurrecting this thread because I wasn't clear enough and maybe someone can still help. Not sure if it is a sensor issue or what but when I first got my car it would tell me at least which tire was running low. Now it is only saying check all four tires even though one will be low and the rest will be fine. So is this a sensor issue? And if so how do I recalibrate them? 2013 Audi A5 Cab.
    Sent from my SM-S918U using Audizine Forum mobile app
    Jul 16 2018
    Atlanta
    You have no sensors on the wheels, there's only the wheel speed sensors mounted in the wheel bearing housings. You have indirect TPMS, it never knows the actual air pressure or air temperature in any of the tires.
    If you've ever rotated tires, changed tires, changed pressure in the tires, or otherwise did anything that would impact the rolling nature of the tires, you'd need to reset the tire pressure system. After that, the system goes into a calibration mode that might take an hour of driving to complete. Once that's locked in, the wheel speed sensor profile for each tire is stored and used as the comparison point going forward.
    Nov 04 2021
    Norfolk, VA
    Thanks. That's helpful!
    Jul 16 2018
    Atlanta
    I reread my post and think one aspect might be misleading. If you change the pressure in the tires, you don't do a "store pressures" or whatever the menu item is in the menu interface under tire pressures for indirect systems. Unless you're changing your normal tire pressure and want it to be your new normal (maybe you used to run 34 but now you want to run 35, etc). It's whenever you change your new normal reference that you do the store pressures recalibration process. Such as rotating tires. You might still be using the same pressures, but now there's a different physical wheel/tire at each corner, so the relearning process needs to be initiated.
    But not just because it got cold for a week and you added a psi or two to bring them back to your normal cold pressure. In case my prior post gave the wrong impression there.
    Nov 04 2021
    Norfolk, VA
    I always do the "store pressures" whenever I add air. My biggest issue is that it doesn't tell me which tire is low. I understand it is an indirect system that sees when rolling dynamics change due to underinflation but it used to tell me, for example "rear right underinflated" but only says check all 4 now.
    I don't know I'll dig deeper.
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    Quote Originally Posted by Tron2013A5 View Post
    Have you tried manually testing it? What I mean is this--- fill all four tires to specs, store the pressures, then after driving around for a while, pull over and lower the pressure by at least 10 psi in just one tire and see what message pops up after you start driving again. It shouldn't take very long for the wheel speed sensors to pick up on the underinflated tire. And it should tell you which tire is underinflated.
    Nov 04 2021
    Norfolk, VA
    Quote Originally Posted by RockJGC View Post
    I did not try that. Will do tomorrow.
