Originally Posted by
20vturbo
This is so stupid. There is no way to get in there with a swivel and a long extension? Wheel bearings go often on these cars, they are retards for this, dropping the subframe is a nightmare
I ended up not dropping the subframe, but I did take the spring pressure off the lower control arm. I probably didn't have to do that either.
I wish I could paste a photo here, but can't, so I'll just describe.
The bearing carrier is held to the hub with four bolts, which come in from the back. The two bottom ones are blocked by an aluminum spacer on a long bolt on the lower transverse link. That bolt and spacer need to come out, and to take pressure off that bolt requires (according to the manual) removing the spring.
What I did instead was to use this spring compressor to pull the spring away from the body of the car:
https://smile.amazon.com/dp/B0028QGT...roduct_details
And then I could remove the interfering bolt and spacer to get out the bottom two bearing bolts.
Unfortunately, Audi specifies that $42 bolt should not be re-used, and if loosened, perform a rear axle alignment.
So $100 for the bearing and bolts, $42 bolt, $140 alignment. Add new tools I bought: $90 breaker bar to tighten the axle bolt and $38 for the spring compressor. I'm not sure I saved much money, but next time I won't have to buy the tools.
