Results 1 to 22 of 22
    Veteran Member Three Rings Patrick Matte's Avatar
    Jun 12 2018
    old car's: Porsche 911 86 3.6 varioram plus G50, elephant racing track suspension, 996 turbo brakes
    Beloeil , Canada
    Show me your best single pulley dragy or slip time !
    Just curious to find out who’s running the best time with the A6 :)
    Be honnest please if you had achieve this time with or without lightweight reduction.
    Envoyé de mon iPhone en utilisant Audizine Forum
    -Audi A6 2012 3.0T-
    IE Stage 1 93 Oct- Melen TCU : 11.72
    IE Stage 2 dual E40 : 11.05
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    i know u beat it with ur stage 1 tune but here is my single pulley epl run
    was low 2500 rpm launch and i belive 6800 rpm shifts.
    left lane, right lane was apr dual pulley car for comparison( he was little more heat soaked then i was)
    im now 034 and dp but havent had chance for a good 1/4 mile run. it did shave a little off my 0 to 60 tho 3.6 now
    irun 93 octane but in ma we have bad gas and see lot of timing pull. lately been running the 91 octane tune with the 93 octane gas n still seeing very little timing correction
    Jun 12 2018
    Beloeil , Canada
    Quote Originally Posted by f4m0u5 View Post
    Same thing happen here im Canada during winter, i need to flash back 91 oct files.
    Thx for sharing tour slip as well!
    -Audi A6 2012 3.0T-
    Sep 16 2020
    West Michigan
    We discussed this in the telegram group chat...
    My car is slow.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jun 12 2018
    Beloeil , Canada
    Quote Originally Posted by sepheroth86 View Post
    My car is slow.
    Hahahaha
    I want to know who got the better time. All go for dual but single pulley is funny too, boost is good and iat stay low! I need to try the E30 file i think :)
    -Audi A6 2012 3.0T-
    Sep 16 2020
    West Michigan
    12.35 @ 113mph, no cooling mods. On a cold day. I don't think that I launched it correctly.
    Jan 26 2019
    Tulsa
    11.91 on e85 tune.
    Jun 12 2018
    Beloeil , Canada
    Quote Originally Posted by Mark.in.tulsa View Post
    11.91 on e85 tune.
    Stage 1 034? Or CREC stage 1 ?
    Post your dragy slip plz.
    -Audi A6 2012 3.0T-
    Jan 26 2019
    Tulsa
    Quote Originally Posted by Patrick Matte View Post
    Crec, SC pulley. I'm looking for the screenshot from my draggy.
    Also I did hit a 3.55 0-60, but didn't get a full 1/4 run on that pull.
    Jan 26 2019
    Tulsa
    Jun 12 2018
    Beloeil , Canada
    TCU Tuned?
    -Audi A6 2012 3.0T-
    Jun 12 2018
    Beloeil , Canada
    I follow you now on dragy :)
    Did you try’ed again in lower DA?
    -Audi A6 2012 3.0T-
    Jan 26 2019
    Tulsa
    I have not. I am way behind on oil change. Have an appointment on Nov 7th to get it changed.
    Plan to go try some more pulls in Mid Nov when it's cooler.
    Jun 12 2018
    Beloeil , Canada
    Will try to do better in more negative DA.
    -Audi A6 2012 3.0T-
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    I'm wondering about everybody's shift points. Do you run it to redline or shift a bit earlier? It seems that if I shift around 6900 I get a bit of a harder shift. Whether or not that actually makes a difference, I don't know. The butt dyno feels great when I do it. Do you use different shift points per gear? First and second gear are gone in a blur and third with it's different gearing takes a bit longer. Anyone experimented with this. Also can you list launch technique? Longer hold in S or M? Begin in S and shift to M? Rev until just before the transmission would settle and release early?
    Jun 12 2018
    Beloeil , Canada
    Quote Originally Posted by WatchMeSpend View Post
    I use 7250 RPM shift point in all gears.
    My launch technique with Melen TCU:
    1) Traction control off
    2) Manual mode
    3) Brake boost at your desired RPM
    4) Release the brake and manage the throttle to not spin ;)
    5) Redline all gears and let the TCU does it job.
    Check how tight your SC belt are and how she look.
    Change your belt and tell me if that improve your shift in high RPM.
    -Audi A6 2012 3.0T-
    Mar 19 2019
    Toronto/Ontario
    2) Manual mode
    I'll have to do some research then. The belt is probably under 2 years old and I don't think I've been beyond 7000 RPM more than 10 times. I have a Berk tune that I put on a year ago so I couldn't rev past 6250 until last September. Berk told me to launch in S and switch to M. He said if I launched in M with a hold longer than a few seconds it was going to break the tires free. Wanted to hit the track today, but couldn't. It was 2 degrees this morning (32F) so the car was feeling rowdy but there was way more traffic than I anticipated and I was on back roads by factories. No good spot or time to launch given how fast the car is going to move.
    I hope to hear from some others and maybe it should be part of the 3.0T quarter mile sticky in regards to launch technique and tune. Some of us might be leaving a few tenths on the table.
    Jun 12 2018
    Beloeil , Canada
    Just a funny dragy tonight. I Did 3 dragy run’s and this is my new best time.
    2600 RPM launch
    Full weight - 1/3 tank - 36 Psi tire pressure
    -Audi A6 2012 3.0T-
    Jun 12 2018
    Beloeil , Canada
    -Audi A6 2012 3.0T-
    Jun 12 2018
    Beloeil , Canada
    https://youtu.be/WzFyvghjAts
    -Audi A6 2012 3.0T-
    Aug 04 2014
    Gloucester MA USA
    nice man!
    Jun 12 2018
    Beloeil , Canada
    nice man!
    Thx! I did 5 pass that day and this is my best ET.
    I did 1.72 60 ft the next run after, iat’s was hotter and then my ET was lower as well. I know i can do better that this.
    -Audi A6 2012 3.0T-
