Originally Posted by
chip_
Now that my car is no longer under Maintenance I am going to start Doing some of it myself so.....
The car is currently up on Jack stands as I am rotating my tires, checking brake pad depth, Tread depth, etc. which is why I am thinking about the below items.
Oil Changes
Gathered some info from this link -
https://www.audizine.com/forum/showt...ractor-Method)
What oil extractor is everyone using? I see Mityvac 7201 Manual Fluid Evacuator mentioned because it can dispense it back into containers after.
What oil service kit are people using and buying it from (ECS, FCP Euro) ?
Is 0W20 oil recommended? Looked at my records and they used LiquiMoly last time and OW20.
Brake fluid Flush
Is this easy enough to do yourself?
Which kit is a good starter kit?
Dust and Pollen filterr
Replaced recently
Spark plugs
What are go to spark plugs?
When should they be replaced?
S-Tronic transmission
Can this be done at home without a lift? I have jack/jack stands
When should this be done?
What is needed if DIY?
Brake Pads
Go to brake pads?
Minus the shit I can't do myself (camera calibration, etc) I do all my own maintenance. Everything is doable with the right tools.
Oil changes are $30 for the return shipping if you do FCP Euro (I do my cabin air filter at the same time as well, every 5000 miles with OEM oil/filter). I use the extractor, the only trick is run the engine for a bit first, otherwise you'll be there all day.
Brake flush is easy if you get this: Motive Products, European Power Brake Bleeder, 0100, Hand Pump Pressure Tank with Adapter
https://a.co/d/aHql3ja
I've bled mine at least 5 times already (for various reasons, no need to do it that often). Get your fluid from FCP Euro as well.
https://www.fcpeuro.com/products/amb...-dot4-dotamber
OEM plugs (purchase anywhere, about $15 each from dealership), you will need this:
ARES 11001 - 14mm Thin Wall Magnetic Swivel Spark Plug Socket with 12-inch Extension - 3/8-Inch Drive 12-Point Spark Plug Socket - Walls 2mm Thinner Than Standard Spark Plug Sockets
https://a.co/d/gK0D91J
There is an entire thread dedicated to brakes, ensure you have either OBD11 or VCDS to open the rear calipers. Pads are either OEM, Hawk 5.0, or EBC
Transmission, Audi swears it's lifetime, ZF says no more than 60K.
