Results 1 to 6 of 6
    Sep 17 2005
    Fremont, California
    The SüperDüper Charger 84mm Throttle Body System is Now Available from 034Motorsport!
    Süpercharge the performance of your B8/8.5 Audi Q5/SQ5 with the 034Motorsport SüperDüper Charger 84mm Throttle Body System! The purpose of this kit is to improve power beyond the factory throttle body found on the supercharged 3.0 TFSI engine in the B8/8.5 Q5/SQ5s, in a clean and cost-effective package.
    Features:
    • Cast and Machined A356 Aluminum Throttle Body Adapter
    • Upgrades to a VDO 84mm Throttle Body
    • Improved Flow Where the Stock Throttle Body Becomes Restrictive
    • 20% Increase in Flow Over the OE Throttle Body
    • Stock 70mm : 380 CFM
    • 034Motorsport Adapter with 84mm Throttle Body: 457 CFM
    • Smooth Transition from the Large Throttle Body to the Supercharger Inlet
    • Throttle Body Adapter and Gasket Can be Port Matched to the Supercharger During
    • Supercharger Porting, Allowing Even More Flow
    • Wire-Reinforced Multi-Ply Silicone Hose
    • Maintains Smooth Inside Surface for Optimum Flow
    • Nylon Breather Tube Connection Nipple
    034MOTORSPORT SÜPERDÜPER CHARGER 84MM THROTTLE BODY SYSTEM
    The 034Motorsport SüperDüper Charger utilizes a VDO 84mm throttle body mated to a cast and machined aluminum throttle body adapter, offering a smooth transition between the larger throttle body to the supercharger inlet. This results in a 20% increase in flow over the OE throttle body right out of the box. Additionally, the throttle body adapter and gasket can be port matched to the supercharger during supercharger porting, allowing for increased airflow.
    034Motorsport Dynamic+ Tuning is required to safely run this SüperDüper Charger 84mm Throttle Body System. Files to support this upgraded hardware are included with our Stage 2+ 91, 93, 100, 104, & E40 octane options free of charge. Simply select the file designated with SüperDüper and you’re good to go! NOTE: This is only for Stage 2+ files. We do not have Stage 1 or Stage 2 files for the SüperDüper Charger.
    Check this out here!
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Nice! when we geting one for the c7 a6/a7!?!
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    the sound is amazing lmao
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Senior Member Three Rings QwertyD's Avatar
    Oct 04 2017
    United States
    Is the throttle body inlet hose included with the throttle body upgrade the same as the one included with the carbon fiber S34 Air intake system?
    Sent from my SM-N986U using Audizine Forum mobile app
    AKA: Dhoang57
    Junior Member One Ring R-o-n's Avatar
    Jul 13 2018
    Ripon/CA
    (Not affiliated with 034, just a fan of their products) - I believe the inlet hose with the Super Duper and the one included with the S34 air intake system are different as the Super Duper inlet hose has a larger 84mm opening to fit the larger throttle body. The S34 inlet hose will not fit the larger Super Duper throttle body.
    Oct 04 2017
    United States
    Quote Originally Posted by R-o-n View Post
    Got it. Thanks!
    AKA: Dhoang57
