Results 1 to 6 of 6
    Junior Member Two Rings
    Oct 13 2017
    saint louis
    Can I transfer TCM from old transmission to new to avoid coding
    My car lost reverse and oil smells burnt lots of black plastic pieces in oil, can I transfer TCM from my transmission to new and avoid programing/coding?
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by audib82011 View Post
    My car lost reverse and oil is burnt lots of black plastic in oil, can I transfer TCM from my transmission to new and avoid programing/coding?
    You may want to specify the year and model of your car
    Oct 13 2017
    saint louis
    Sure its 2011 a4 2.0 with cvt transmision
    Oct 13 2017
    saint louis
    I read somewhere that it can be done as long as the tcm is in working condition and not damaged, can anyone confirm
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    You’ll be good. The component protection (immobilizer) is built into the tcu/valve body/ circuit board whatever you want to call it so by switching that over to the new trans no coding will be required.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Yes.
    B6 S4, B8 A4, 8P A3, and something, something.
