Results 1 to 2 of 2
    Sep 17 2005
    Fremont, California
    High Output Ignition Coil for EA8XX Engines Now Available From 034Motorsport!
    Available Now: High Output Ignition Coil for EA8XX Engines!
    Check them out here: https://034ms.com/EA8XXHOIC
    The 034Motorsport Ignition Coils are designed to be a Higher Output, direct plug-and-play upgrade from OE ignition coils with improved heat dissipation via the integrated CNC-Machined heat sinks and offer unique, colorful styling.
    The 034Motorsport High Output Ignition Coils offer a 10% increase in energy output which is perfect for those looking to maximize output from their stock or modified cars. With integrated CNC-machined heat sinks, any excess heat can be transferred from the ignition coil, further improving the performance of the coils. Crucially, 034Motorsport High Output Ignition Coils are available in red to show everyone at the local car meet that you value performance in the streets, the sheets, and the track!
    For 6 Cylinder applications like the B9/B9.5 EA839 3.0T and 2.9TT engines, the factory engine harness sits atop the factory ignition coils, reducing airflow across the coils. With the selection of our Pack of 6, we include Billet Aluminum harness bracket spacers to raise the harness off of the ignition coils without adding strain to the wiring harness, allowing for proper space between the wiring harness and the heat sinks.
    FEATURES:
    • 10% Increase in Energy Output over Stock Ignition Coils
    • CNC-Machined Heat Sink for Better Heat Dissipation
    • Red Housing with 034 Logo
    • Direct Plug-And-Play
    • Engine Harness Mounting Spacers included with Pack of 6 for V6 engines to Allow for Proper Airflow Across Heat Sinks (*Must Select Pack of 6 for these to be included, required for all EA839 V6 engines!*)
    OE PART INTERCHANGE:
    • 06J 905 110 D
    • 06J 905 110 E
    • 06K 905 110 D
    • 06J 905 110 F
    • 06J 905 110 G
    • 06H 905 110 G
    • 06J 905 110 K
    • 06H 905 110 H
    • 06H 905 110 L
    • 06J 905 110 N
    Available Now: https://034ms.com/EA8XXHOIC
    Nov 24 2018
    Detroit
    Cool.
    Any news on an ECU tune for a platform that is going on 7 years old, or shall we continue giving your competitors business instead?
